Seeking input from those of you that are using the Flightstream 110 or 210.   I am attaching to a GTN 750 navigator and would like to know if any of you have the fligthstream located in the aft avioinics bay or nearer to the cockpit.   If located in the aft avionics bay do you have any issue with connectivity?
Thanks in advance
Warren
I no longer have the FS 120 but when I did it was located in the rear avionics bay of my M20J and I had no issues at all with BT connectivity.
I have the FS 210, have located it in the rear avionics bay, and have had no issues with it.
Thanks in advance
Warren
Mine is resting right onto of the 750, behind the panel
