Well, it is now done in the US as well.
we got the flight stream working on my acclaim.
Brian Kendrick has the only install in the US under his belt.
I can’t wait to have this feature enabled in my g1000. It was the only thing I really missed from the NXI.
This is great news!
So in theory, could one stream internet weather to the G1000 via the FlightStream?  Would it know any different from ADS-B?
-dan
-dan
Good question.
with the 3.7 software you get xm and Adsb weather so that is not something I care about,  and wouldn’t know how to check it, since I already receive it, but I would imagine the flite stream could send whatever info it had to an phone or a tablet.
edit
but I am pretty sure you need 3.7 to install this unit.
-dan
No.. the Connext protocol interface is configured only for the flight plans.    the .37 software will already accept the radar mosaic from either XM or ADSB-UAT  (the previous software had a bug with ADSB)
For the FS210 to stream the ADSB data you need to connect it to the 345R (or 88).   this also puts the bluetooth point in the cabin, removing the delivery from the rear access problems.
This is great news!
Awesome, how much did it end up costing you if you dont mind me asking ?
Ok, it was approximately 3k to supply and install the flight stream 210.  I had an available breaker that was used for a CD player, and I had the .37 software. I’m sure there will be some variances for each plane, but I double checked with Brian and that is a reasonable budget.
The best 3k I have ever spent for an upgrade. This was the single best upgrade that was in the NXI.
If you don’t fly ifr much, you won’t likely see the value in this upgrade, but where I live involves a minimum of four reroutes regardless of how I file, and atc never provides transitions for airways which makes entering them in the g1000 a challenge.
with the flight stream all you have to do is type it your phone or tablet and send it to the gps. MUCH easier!
On 3/23/2025 at 4:21 AM, Schllc said:
Not sure yet, haven’t gotten the bill.
Dang for that price its super worth it. I am going to reach out to Brian and get some time on his schedule to get it installed in my plane.
