Marc_B Posted November 7, 2024 Report Posted November 7, 2024 Have Hartwell latches on my oil filler access door and two of the springs are rusted out and near breaking. Lasar used to sell the latches, but no longer available. However, all I need is the simple spring...does anyone have a product number/dimensions for spring and a source for purchase? The latch is Hartwell H-4600-051-115 if that helps. Thanks! Quote
alextstone Posted November 7, 2024 Report Posted November 7, 2024 Perhaps this would contain what you need: Amazon Spring Kit https://a.co/d/7Ywp9XF 1 Quote
Hank Posted November 7, 2024 Report Posted November 7, 2024 Check with Lee Springs. You'll need to know wire diameter, the outside diameter of the spring and the length of the spring when it's out of the latch, laying on the table. Note that it may be cheaper to buy a couple dozen springs than just a couple. Lee Springs makes a zillion springs in multiple materials and all kinds of sizes. Measure carefully with calipers to assure a good fit. 1 Quote
IvanP Posted November 7, 2024 Report Posted November 7, 2024 McMasterCarr should have something what would meet your needs https://www.mcmaster.com/products/springs/springs-2~/spring-type~extension/ 1 Quote
AJ88V Posted November 7, 2024 Report Posted November 7, 2024 Oh, I'd be worried about the 337! 2 Quote
Marc_B Posted November 7, 2024 Author Report Posted November 7, 2024 I found these...HARTWELL LATCH SPRINGS H4609 FOR H4600 / H5000 LATCHES SET OF 5 https://www.ebay.com/itm/264774515036 McMaster or Carr could probably sell some to spec but not sure the size without taking off and measuring...I couldn't find a spec online for a H4609 spring nor a parts diagram for the Hartwell latch. The ebay springs are cheap enough that I'll probably just order a package and see if they're the right spring. Quote
IvanP Posted November 7, 2024 Report Posted November 7, 2024 20 minutes ago, AJ88V said: Oh, I'd be worried about the 337! Might also need an STC for 1 AMU Quote
EricJ Posted November 7, 2024 Report Posted November 7, 2024 +1 to just find a box of springs or something similar and replace it. This pretty much fits the description of "small standard parts". It just needs to be able to do the job. They're easy to inspect and replace. Quote
N201MKTurbo Posted November 8, 2024 Report Posted November 8, 2024 https://www.wicksaircraft.com/shop/h4600-hartwell-latch/?woo_id=239164&gad_source=1&gbraid=0AAAAACWeXA-kX5qNWOccishueH_wiytUd&gclid=EAIaIQobChMIzr-erunLiQMVLShECB3JoSGCEAQYASABEgJlCfD_BwE 1 Quote
hypertech Posted November 8, 2024 Report Posted November 8, 2024 I was also missing some. Bought a couple NOS switches from eBay and took them from there. Easy peasy. Quote
mike_elliott Posted November 9, 2024 Report Posted November 9, 2024 On 11/7/2024 at 5:36 PM, Marc_B said: Have Hartwell latches on my oil filler access door and two of the springs are rusted out and near breaking. Lasar used to sell the latches, but no longer available. However, all I need is the simple spring...does anyone have a product number/dimensions for spring and a source for purchase? The latch is Hartwell H-4600-051-115 if that helps. Thanks! I may have one still I’ll check. I gave most of my aircraft hardware to @junkman when I gave up my hangar, but I’ll look in a bit. Quote
mike_elliott Posted November 9, 2024 Report Posted November 9, 2024 21 minutes ago, mike_elliott said: I may have one still I’ll check. I gave most of my aircraft hardware to @junkman when I gave up my hangar, but I’ll look in a bit. Yep, found it Quote
Marc_B Posted November 9, 2024 Author Report Posted November 9, 2024 @mike_elliott I didn't need a complete latch but rather wanted to replace the rusted springs. I'll see if the ebay order are the correct springs and will PM you if they aren't the right springs. But that does look like the same latch on my oil door. Quote
mike_elliott Posted November 9, 2024 Report Posted November 9, 2024 It should be I got them from Mooney when I needed to replace one on my F years ago because the hole for the latch pin elongated and would pop open in flight. the 2nd latch held fortunately. Anyway, let me know if you decide you need it, and we can go from there. 1 Quote
