EricJ Posted August 29, 2024 Report Posted August 29, 2024 That's probably the cap for the alternator output filter. 2
PT20J Posted August 29, 2024 Report Posted August 29, 2024 1 hour ago, EricJ said: That's probably the cap for the alternator output filter. This^^^^
MikeOH Posted August 29, 2024 Report Posted August 29, 2024 1 hour ago, EricJ said: That's probably the cap for the alternator output filter. Given the distance the cap is from the alternator must have been a CE vs. RE problem. Not that an electrolytic would be very effective for most RE anyways.
EricJ Posted August 29, 2024 Report Posted August 29, 2024 2 hours ago, MikeOH said: Given the distance the cap is from the alternator must have been a CE vs. RE problem. Not that an electrolytic would be very effective for most RE anyways. I think so. It's just trying to keep the power system reasonably clean, especially in the context of the few of decades of transition into transistors where noise immunity was way worse than it was for stuff that ran on tubes. 1
