Brian2034 Posted May 15, 2024 Report Posted May 15, 2024 (edited) I know the topic has been discussed dozens of times! But I can’t seem to find a definitive answer on operating RPM limitation for my particular aircraft 1962 M20C The POH that came with the aircraft looks brand new and I think it’s a generic POH for multiple years? It shows no restriction? Edited May 15, 2024 by Brian2034 Quote
Fly Boomer Posted May 16, 2024 Report Posted May 16, 2024 53 minutes ago, Brian2034 said: It shows no restriction? I think the factory can produce a POH for your serial number. 1 Quote
47U Posted May 16, 2024 Report Posted May 16, 2024 1 hour ago, Brian2034 said: The POH that came with the aircraft looks brand new and I think it’s a generic POH for multiple years? Is it the booklet POH (see pic)? Mooney produced an ‘Owner’s Manual’ to provide additional information lacking in the POH that came with the aircraft when delivered. You should have a POH that’s on 8.5 x 11 typing paper. It will have your serial number on it and factory weight and balance data with as-delivered optional equipment. At least, that’s what I have for a POH on my ‘63C. Quote
PT20J Posted May 16, 2024 Report Posted May 16, 2024 The TCDS should be definitive. https://drs.faa.gov/browse/excelExternalWindow/6EA0F05ECCA8304486258305006833CF.0001?modalOpened=true 2 1 Quote
PT20J Posted May 16, 2024 Report Posted May 16, 2024 By the way, Pilot's Operating Handbooks did not exist before GAMA issued it's specification 1 in 1975. Earlier documents were operating manuals, operating instructions, owner's manuals or whatever the manufacturer wanted to call them and varied in information content. 3 Quote
Ragsf15e Posted May 16, 2024 Report Posted May 16, 2024 Also, if you’re airplane has a different prop stc, that could have a different yellow arc restriction. What prop do you have? 4 Quote
M20F Posted May 16, 2024 Report Posted May 16, 2024 7 hours ago, Ragsf15e said: Also, if you’re airplane has a different prop stc, that could have a different yellow arc restriction. What prop do you have? This is relevant. Quote
Shadrach Posted May 16, 2024 Report Posted May 16, 2024 13 hours ago, Ragsf15e said: Also, if you’re airplane has a different prop stc, that could have a different yellow arc restriction. What prop do you have? Indeed and those installations should come with revisions to the limitations section of the operating manual/POH as well as a placard for the tach with a revised yellow/red arc. Quote
Hank Posted May 16, 2024 Report Posted May 16, 2024 1 hour ago, Shadrach said: . . . a placard for the tach with a revised yellow/red arch. I have a small placard, but there's no Yellow for my Hartzell 3-blade. Quote
Shadrach Posted May 16, 2024 Report Posted May 16, 2024 13 minutes ago, Hank said: I have a small placard, but there's no Yellow for my Hartzell 3-blade. Nope...I's clearly read just like the one in my plane running two blade Hartzell on your arc is narrower. Quote
Hank Posted May 16, 2024 Report Posted May 16, 2024 1 hour ago, Shadrach said: Nope...I's clearly read just like the one in my plane running two blade Hartzell on your arc is narrower. That's likely C vs F engines rather than the props. My Airspeed Indicator has a yellow stripe from 175-200 mph, though. Quote
Shadrach Posted May 16, 2024 Report Posted May 16, 2024 17 minutes ago, Hank said: That's likely C vs F engines rather than the props. My Airspeed Indicator has a yellow stripe from 175-200 mph, though. My arc changes if I change props. Some will eliminate the arc all together. 2 Quote
Brian2034 Posted May 21, 2024 Author Report Posted May 21, 2024 On 5/16/2024 at 4:00 PM, Shadrach said: My arc changes if I change props. Some will eliminate the arc all together. Okay The prop is a HC-C2YK-1BF two blade on a O-360-A1B Quote
