Matthew P Posted May 9 Report Posted May 9 1966 M20E, looked through parts manual didn't see it but looking for the rubber trim piece that goes between the space where the vertical and horizontal tail surfaces meet, anyone have a part number or alternate source? Quote
Shadrach Posted May 9 Report Posted May 9 It is "U" channel trim piece. There are several off the shelf products that will work. I do not recall the correct size. you should perhaps remove and measure a small piece to ensure you order the correct size. I think this company has been used by others: https://www.trimlok.com/catalog Quote
Fly Boomer Posted May 9 Report Posted May 9 2 hours ago, Matthew P said: rubber trim piece Brown sells a variety of trims and seals. You will need to look around on their web: https://www.brownaircraft.com/T-11-Black-or-White-1-2in-U-Channel-25-Ft-Package-p/t-11.htm 1 Quote
Shadrach Posted May 9 Report Posted May 9 23 minutes ago, Fly Boomer said: Brown sells a variety of trims and seals. You will need to look around on their web: https://www.brownaircraft.com/T-11-Black-or-White-1-2in-U-Channel-25-Ft-Package-p/t-11.htm The fact that Brown makes it in white makes it an easy choice. Quote
outermarker Posted May 10 Report Posted May 10 Is there a trick to putting it on? Any special tools required? Quote
