corn_flake Posted February 10, 2024 Report Posted February 10, 2024 Does any one knows the size of grease fitting on M20E's landing gear? My IA and I broke the one all the way in the more recess area of the gear. Now I'm on the hunt to find replacement. Quote
Kelpro999 Posted February 11, 2024 Report Posted February 11, 2024 (edited) On 2/10/2024 at 7:35 PM, corn_flake said: Does any one knows the size of grease fitting on M20E's landing gear? My IA and I broke the one all the way in the more recess area of the gear. Now I'm on the hunt to find replacement. Expand Search eBay; zerk 6-40 unf Alemite #3018 6-40 UNF-2A usual broken one Edited February 12, 2024 by Kelpro999 Quote
N201MKTurbo Posted February 11, 2024 Report Posted February 11, 2024 They are in the parts manual. 1 Quote
M20F Posted February 11, 2024 Report Posted February 11, 2024 And given 50+ years the size is the size find what fits. Quote
EricJ Posted February 11, 2024 Report Posted February 11, 2024 They qualify as standard parts, and they're pretty common, so no need to overspend. 1 Quote
N201MKTurbo Posted February 11, 2024 Report Posted February 11, 2024 The part numbers specified in the parts manual are all available on line for little money. You might as well use the right parts. Quote
M20F Posted February 12, 2024 Report Posted February 12, 2024 On 2/11/2024 at 11:55 PM, N201MKTurbo said: The part numbers specified in the parts manual are all available on line for little money. You might as well use the right parts. Expand The right parts often don’t fit anymore because they were fitted with larger fittings when the original snapped out. Quote
N201MKTurbo Posted February 12, 2024 Report Posted February 12, 2024 Mooney used these fittings: Quote
N201MKTurbo Posted February 12, 2024 Report Posted February 12, 2024 It was supposed to attach the whole catalog, but it only did the cover. Quote
PT20J Posted February 12, 2024 Report Posted February 12, 2024 At least on the M20J, some were screw in and some were press fit. Quote
CaptainRamius Posted February 12, 2024 Report Posted February 12, 2024 LockNLube has a neat tool to extract the grease fittings and retap if necessary. Zerks on my M20C are not standard. 2 different sizes on NLG. Some 7/32" others seems to be 7mm. IDK how metric can be on a 65 American airplane. https://locknlube.com/products/grease-fitting-multi-tool-small Quote
EricJ Posted February 12, 2024 Report Posted February 12, 2024 On 2/12/2024 at 3:51 AM, CaptainRamius said: LockNLube has a neat tool to extract the grease fittings and retap if necessary. Zerks on my M20C are not standard. 2 different sizes on NLG. Some 7/32" others seems to be 7mm. IDK how metric can be on a 65 American airplane. https://locknlube.com/products/grease-fitting-multi-tool-small Expand Somebody may have tapped it with a metric tap if it got stripped out or something. Quote
N201MKTurbo Posted February 12, 2024 Report Posted February 12, 2024 On 2/12/2024 at 3:32 AM, PT20J said: At least on the M20J, some were screw in and some were press fit. Expand They are all in the above catalog. With the exact part numbers from the parts manual. 1 Quote
corn_flake Posted February 15, 2024 Author Report Posted February 15, 2024 Thanks guys!! Well, I went with the parts catalog and orderd MS15002-1. Let's hope it works when the broken piece comes out. Finger crossed. Quote
