Lax291 Posted January 23, 2024 Report Posted January 23, 2024 Might be kicking a hornets nest here, but is there a definitive answer on if the new(ish) WAT LED recognition lights can be pilot installed and signed off? Did a search online for forum answers and didn't find anything. Quote
Fly Boomer Posted January 23, 2024 Report Posted January 23, 2024 15 minutes ago, Lax291 said: Might be kicking a hornets nest here, but is there a definitive answer on if the new(ish) WAT LED recognition lights can be pilot installed and signed off? Did a search online for forum answers and didn't find anything. Use your browser-based search engine -- not the search built in to the forum software. First hit: https://mooneyspace.com/topic/41571-recognition-lights-this-is-how-it-done/?do=findComment&comment=833911 Quote
PT20J Posted January 24, 2024 Report Posted January 24, 2024 "Replaced left and right recognition light bulbs with Whelen 01-0770303-20." 1 Quote
RoundTwo Posted January 24, 2024 Report Posted January 24, 2024 Yes. I did it with a simple sign off. Quote
Lax291 Posted January 24, 2024 Author Report Posted January 24, 2024 On 1/23/2024 at 7:28 AM, Fly Boomer said: Use your browser-based search engine -- not the search built in to the forum software. First hit: https://mooneyspace.com/topic/41571-recognition-lights-this-is-how-it-done/?do=findComment&comment=833911 Thanks for mentioning that, I do use the browser and it does a much better job. In the post, I didn't see what I would call a "definitive" answer. 9 hours ago, PT20J said: "Replaced left and right recognition light bulbs with Whelen 01-0770303-20." Did you make this entry as a PP? 3 hours ago, RoundTwo said: Yes. I did it with a simple sign off. Via an IA/A&P? Quote
Fly Boomer Posted January 24, 2024 Report Posted January 24, 2024 37 minutes ago, Lax291 said: Thanks for mentioning that, I do use the browser and it does a much better job. In the post, I didn't see what I would call a "definitive" answer. Did you make this entry as a PP? Via an IA/A&P? “Definitive” is elusive in matters such as this. Just do what @PT20J said. If somebody gets their panties in a twist later, you can beg forgiveness and get someone further up the food chain to fix the log. Quote
LANCECASPER Posted January 25, 2024 Report Posted January 25, 2024 On 1/23/2024 at 6:13 AM, Lax291 said: Might be kicking a hornets nest here, but is there a definitive answer on if the new(ish) WAT LED recognition lights can be pilot installed and signed off? Did a search online for forum answers and didn't find anything. I wouldn't overthink it. I would do something close to what @PT20J did, only maybe a little further: "Replaced inop left and right recognition light bulbs with Whelen direct replacement 01-0770303-2" Quote
OR75 Posted January 25, 2024 Report Posted January 25, 2024 On 1/23/2024 at 4:13 AM, Lax291 said: Might be kicking a hornets nest here, but is there a definitive answer on if the new(ish) WAT LED recognition lights can be pilot installed and signed off? Did a search online for forum answers and didn't find anything. Are you going to remover the power supply of the existing strobes ? it may require a new w&b entry in the POH Quote
Lax291 Posted January 25, 2024 Author Report Posted January 25, 2024 Thanks for the guidance guys. I didn't think there was a need for new W&B as I also didn't think the power supplies were driving the recognition lights. Quote
OR75 Posted January 25, 2024 Report Posted January 25, 2024 7 hours ago, Lax291 said: Thanks for the guidance guys. I didn't think there was a need for new W&B as I also didn't think the power supplies were driving the recognition lights. what do you currently have installed ? the LED strobe/lights do not require a power supply (the power supply is embedded in the strobe/light assembly, that's a big part of the beauty of LEDs. Low need for power / amps !. the LED is connected directly to the ground/12v of the ship via (of course) a circuit breaker If your plane currently has position/strobe light you will need to bypass the power supply boxes (usually one near each wingtip bolted to the last inspection panel) Quote
Fly Boomer Posted January 26, 2024 Report Posted January 26, 2024 3 hours ago, OR75 said: what do you currently have installed ? the LED strobe/lights do not require a power supply (the power supply is embedded in the strobe/light assembly, that's a big part of the beauty of LEDs. Low need for power / amps !. the LED is connected directly to the ground/12v of the ship via (of course) a circuit breaker If your plane currently has position/strobe light you will need to bypass the power supply boxes (usually one near each wingtip bolted to the last inspection panel) I could be wrong, but I think the original question was looking for specific authorization and logbook language for swapping out the recognition lights, not strobes. 1 Quote
Lax291 Posted January 26, 2024 Author Report Posted January 26, 2024 You are correct @Fly Boomer but appreciate the willingness to help @OR75 Quote
RoundTwo Posted January 29, 2024 Report Posted January 29, 2024 On 1/24/2024 at 8:57 AM, Lax291 said: Thanks for mentioning that, I do use the browser and it does a much better job. In the post, I didn't see what I would call a "definitive" answer. Did you make this entry as a PP? Via an IA/A&P? My sign off was done by a field A&P. Quote
Jetpilot86 Posted January 31, 2024 Report Posted January 31, 2024 I was told I could, but am having Maxwell do it while in annual this week. I ran out of time for pre annual projects. Quote
