Usually when the old starters fail people just replace them with a SkyTec or B&C, both of which are much lighter and turn the prop faster than the original starter.
Otherwise you might be able to take it to an electric motor shop to get it repaired.   The original starter is essentially a tractor starter.
The coil was “shunted” and will trip the 10 amp breaker for the solenoid
AI and I installed the PMA solenoid from spruce…
to reduce wire tension, we had to push slack starter wire from engine compartment into the cab.
