If the caps are too difficult to open , then they require adjustment. It is a very simple procedure.  Remove the cotter pin, loosen the nut. Test to see that it is easier but still tight enough to seal.  Upon completion of the test , install a new cotter pin.
 I never let the fuel personnel put the caps back on.  If they get cocked , it makes them difficult to open again, even if properly adjusted.
