We are assembling a project M20 E super 21 and are putting a new oil cooler in the stock location, the hoses seem to fit better with the cooler installed with the hose fittings on the top.  Is there a reason that this is not advisable?  they will run alongside the block far above and away from the exhaust pipes where they used to go.
Your thoughts??
Your thoughts??
Perhaps sediment. Dropout during reduced velocity near bottom of cooler. Don’t know exactly but you asked for thoughts :D
I would do whatever the service manual/IPC shows.
If the hoses are old and not teflon, you might want to replace them and double check that the sizes agree with the IPC.
Your thoughts??
What are you using as a reference? Who is doing the work? The factory routing of the oil hoses is down the outside of the rear baffle wall and then forward under the exhaust system. There should be a heat shield built into the floor of the lower cowl just inside the cowl flap to protect the hoses. I can find no supporting documentation for doing it as you suggest. Does the plane have a modified/aftermarket cowl?
Edited by Shadrach
Your thoughts??
One consideration is the engine movement on the mounts….so you need to account for this if routing on the engine.  Don’t want to add load to the oil cooler since those hoses are stiff and have a over arm that can induce cracking.  Would need to figure a way to allow for some movement….
Use adel clamps to secure hoses in a specific location
teflon is 25% smaller o.d.
I swage one fitting, install firesleeve and then swage other fitting.
all others per there tso most build hose assembly, and then slide on sleeve.
This method makes a bulky hose assy
GB
17 hours ago, McMooney said:
Just replaced mine, here's a pic
Where are your lower cowl support rods? Your oil cooler has different stand-offs than most. To the OP, Yes it’s tight. If you were to mount the cooler the other way I would suspect it would catch on the ram air cable and be close to the mixture. I’d leave them on the bottom and have the hoses manufactured with smooth 90°s on them if needed.
-Matt
GB
Do you have the dimensions/specs for oil cooler lines and the prop governor flex line for a 1964 M20E, or would I need to measure them to order?
Looks like a doubler was added where the supports would mount and they were never reinstalled.
I suggest some vinyl hose from ace hardware for routing and proper length
This is how I do mock-ups
brass slip on fittings and tubing
Damn good idea  Learn something new every day even if  you are an old dog! :-)
Excellent advice and if I may add cutting cardboard to mimic the hose minimum bend radius helps prevent exceeding specifications during mockup.
-Matt
Hmm, that i do not know, please show a pic of a model with these lower supports
9 hours ago, McMooney said:
Just Guessing,  but looking in the service / parts manuals, my model never had lower supports
Interesting. I have never seen a vintage Mooney without cowl supports.  74 was the first year production year under Republic Steel's ownership. There were loads of changes and omissions throughout the late 60s and into the 70s.  I'd be interested to see if they devised some other method of supporting the cowl.  Seems too heavy to just cantilever off the firewall. The upper cowl and intake add support when assembled. Is there additional structure supporting the cowl that can't bee seen?
You may want consider fire sleaving the original hose did not have it installed. Also if I recall correctly one those or could mine particular airplane the adel clamps where something like -3 bolt #10 with 3/8” wrench head size but the hard to get to was another size smaller something like 11/32” wrench head size or could have been 5/16” wrench size. Much easier to see when engine not installed.  I have done both way with engine installed and not.
good luck with your project.
james ‘67c
