Im about to purchase an M20J 205 with an upgraded IO 390 engine and Im looking to see if anyone has a performance profile for this setup?
Search.  There are several threads on this and some other boards about the IO-390 conversion.
But think of this, a 231 and 252 are 210 HP also.  So should be similar to them down low, but is not much difference.   You need a LOT of HP to go faster.
It climbs a bit better and you get a couple of knots more.  At cruise power, you’ll only have ~7 more hp.  Roughly.  From the other folks on here, the change was noticeable mostly in climb.  Less so in cruise.
It’s a newer design and has all the improvements incorporated into the newer versions of the io-360.
I see that IO-390 as a super idea going from a 180.
Like the Extreme Decathlon.  Super is AEIO-360 180 HP, Extreme is AEIO-390 210 HP.  30 HP is a HUGE difference in take off and climb performance.  And vertical performance for aerobatic aircraft.
Yes but for M20F that is only 5% increase in the power which equals 1.6% increase of the speed.
Climb performance would be noticeable, though.
  • 2 weeks later...
Expand
It's limited to 5 minutes above 200hp as well.
