Trying to find oil filter. Anyone know the difference between a Champion CH48108-1 and Tempest AA48108-2
Can I use the Tempest ?  Cant seem to find the CH48108-1 anywhere. Any advice ?
Yes you can
I like the tempest filter and use it on mine. Do not put oil on o-ring. The EZ function of the ring already has chemicals in the ring to help it to easily be removed when required. Also get a torque wrench on the filter for installing. Tried the hand tight and then another 3/4 turn and that was not enough it started leaking. After torquing it i was surprised just how tight the filter needs to be but it does not leak.
Pre fill the filter with oil before installing it on your Continental engine.
11 hours ago, Fly Boomer said:
What’s the strategy for an upside-down filter on a Continental 520?
There are special order versions with a filler cap on the top of the filter for use on the 520 series, but never install these on a TSIO-360 in a K model they leak when installed upside down.
You can always punch a hole in it and fill it with oil carefully and then screw a drywall screw into the hole to seal it. ;)
Got a web link or source for those filters?  :)
