More parts. I owned and M20C for 34 years, owned an M20A for 15 years (I had the C & A at the same time) and now have a 201 J. When I recently upgraded to a J, realized I have way too many spares that I don't need. Let me know what you are looking for, I may have it.
Just call or text with questions - thanks Gary 6O8 334 OO51
  • 2 years later...
12 hours ago, Darrell Donnelly said:
Hello, I am looking for firewall forward for a 1965 Mooney super 21. I have all the cowlings but need engine mount and so on. I would be interested in an engine if you have one
cheers
Darrell Donnelly
donnel@tbaytel.net
800-563-5423
@Gary Bymers
  • 5 months later...
looking for the step servo. mod BI-706, pn 4059-1 or perhaps just the parts to fix the one i have. The rubber skirt on the plunger is torn and if there is an apron to prevent total vacuum leak, would need that as well ( i believe there are a series of these things, if you have one with the same ID, could probably use the parts to fix mine, which leaks like a seive)image.jpeg.13d3837c9271f2aa554b127071e2d5f7.jpeg
Would you happen to have any wheels (nose or main) in there by any chance? Looking for my M20G, should be the same as C-K with serials 670001. Thank you!
I have one that's in pretty good shape and it worked fine in my plane before we replaced it with the electric step, but I do think there is a tear in the boot. It wasn't enough to cause it not to work, but it's there. Let me know if you're interested.
