If anybody has schematic 800350 K2 (both sheets) from the M20K Service and Maintenance Manual number 134 for a 1989 M20K 252, I would greatly appreciate a copy.  The manual says they are located in the "envelopes at the back", but the copy I have didn't include the contents of the envelopes.
The file I have for original manual doesn't include them either.  But I have M20K revision B that may have what you're looking for.  (EDIT: The file is incorrectly labeled "1994"...what I meant was 2014 revision.  and it actually attached the entire manual as well if you need it.)
Otherwise, maybe Mooney could send you the blow-up fiche that you're looking for.
Marc.
m20k service manual 2014 rev.pdf schematics_M20Krevision1994.pdf
Edited by Marc_B
correction
