PeytonM Posted November 5, 2021 Report Posted November 5, 2021 One consideration for my panel upgrade is adding AoA. I have one on my AspenProMax, but unfortunately that device is not compatible with the A/P that I’ve selected. Furthermore, I found the AoA on that screen outside of my scan during final phases of landing not as helpful, but maybe that’s just me. I’m looking for input from pilots who have added AoA, which one and how useful they have found it. I’m biased towards a glare shield mount because that’s where your eyes are during final phases of landing. Thanks in advance. Peyton
donkaye, MCFI Posted November 5, 2021 Report Posted November 5, 2021 I have the Alpha Systems Eagle with HUD on my glare shield, and use it on every landing. Calibrated properly, it caused me to reduce my approach speed by nearly 5 knots. 2
Jerry 5TJ Posted November 5, 2021 Report Posted November 5, 2021 I elected to go with the glare shield mounted "Eagle" display. 1
aviatoreb Posted November 5, 2021 Report Posted November 5, 2021 On glare shield AOA is definitely the way to go for many reasons - eyes down the runway and not in the cockpit looking at a AOA or a ASI. One does not need the HUD display to get an excellent on glare shield AOA. Here is my device that is just a light bar, but down at the end of the glare shield and serves entirely the same utility as the hud display. But you see it lies flat so no hud needed. 2
Ragsf15e Posted November 6, 2021 Report Posted November 6, 2021 7 hours ago, aviatoreb said: On glare shield AOA is definitely the way to go for many reasons - eyes down the runway and not in the cockpit looking at a AOA or a ASI. One does not need the HUD display to get an excellent on glare shield AOA. Here is my device that is just a light bar, but down at the end of the glare shield and serves entirely the same utility as the hud display. But you see it lies flat so no hud needed. Which one do you have? Looks good!
bmcconnaha Posted November 6, 2021 Report Posted November 6, 2021 nice thing about the aspen is its calibrated with and without flaps... i think its the best solution to not have to add any other hardware. we have a g3x going in my plane now, but it requires another pitot tube.
exM20K Posted November 6, 2021 Report Posted November 6, 2021 12 hours ago, donkaye said: Calibrated properly, it caused me to reduce my approach speed by nearly 5 knots. Hi, Don. Curious - what are the before/after numbers in terms of 1.? Vso? I find something around 1.25 works very well to shorten landings. -dan
donkaye, MCFI Posted November 6, 2021 Report Posted November 6, 2021 13 minutes ago, exM20K said: Hi, Don. Curious - what are the before/after numbers in terms of 1.? Vso? I find something around 1.25 works very well to shorten landings. -dan I calibrated the donut at 1.3Vso. No quick mental calculations are necessary for weight dependent final approach speed. At gross weight the donut appears at about 71 knots. 2
Oscar Avalle Posted November 6, 2021 Report Posted November 6, 2021 This is how I have mine installed. I am just having difficulties calibrating it.Sent from my iPhone using Tapatalk Pro
Ragsf15e Posted November 7, 2021 Report Posted November 7, 2021 2 hours ago, Oscar Avalle said: This is how I have mine installed. I am just having difficulties calibrating it. Sent from my iPhone using Tapatalk Pro Nice panel! What the heck is this?! 1
Oscar Avalle Posted November 7, 2021 Report Posted November 7, 2021 20 hours ago, Ragsf15e said: Nice panel! What the heck is this?! his Long story... He belonged to my son Fausto. He flew with me once with his "friend". Once we landed he told me that his friend would always fly with me to keep me company... so here I am... 3 1
Ragsf15e Posted November 7, 2021 Report Posted November 7, 2021 37 minutes ago, Oscar Avalle said: Long story... He belonged to my son Fausto. He flew with me once with his "friend". Once we landed he told me that his friend would always fly with me to keep me company... so here I am... That’s awesome! I’d have him right there too!
kpaul Posted November 8, 2021 Report Posted November 8, 2021 I have the CYA-100 installed. The display was mounted into the edge of the glare shield. It is very easy to keep in your scan. In the below picture you can see the red light illuminated.
PeytonM Posted November 24, 2021 Author Report Posted November 24, 2021 Would you do it all over again? Would the GFC500 keep you out of a stall/spin scenario, base to final turn?
jamesm Posted November 30, 2021 Report Posted November 30, 2021 I too have the the CYA-100 AOA installed in a '67C. I have very limited room so other AOA's weren't really an option for me. since there isn't space on the so called dashboard above the instrument panel. I installed the CYA-100 indicator between the Mechanical/pneumatic Airspeed Indicator and the G5. honestly I over look it in my scan(room for improvement on my part). On My base to final turn my left eye verifying that I am at 80 mph on the Mechanical/pneumatic Airspeed Indicator. The rest of my scan is verifying sink rate is reasonable and my pitch is where it should be. After many practice landings with a little bit muscle memory stored up and having a good sight picture my landings consistent (most days) and have become quite adequate. I don't even notice the GFC-500 ESP presence since I am not typically over banking the airplane in this phase of flight. The GFC-500 ESP is similar to the Brittian wing lever PC (Positive Control) system in that the system is always on (unless it is re-configured it). of course the common complaint (by non Mooney pilots) of Mooney's ailerons are too heavy . Which after flying with the PC on a few times I didn't even noticed until I remove the PC system after the Turn Coordinator finally died. Boy did I really miss the wing lever. Personally, I think there is possibility to stall spin the plane in base to final turn even with GFC-500's ESP engaged. you should get a "STALL" "STALL" aural warning and the "STALL" display annunciation on the G5 though it may not be enough. if a person were to panic in such way to over ride the autopilot ESP function. if you are in the panic mode it's has been my experience that people tend to freeze and may not be fast enough to recognize the stall spin in the base to final turn scenario. It is my understanding that the stall spin happens so quick that you are probably not going have time to recover. To my way of thinking it more of situation awareness tool like ADS-B is where we still have to be on the look out for other traffic. I like Paul Bertorelli's explanation. for what it is worth this is just my opinion. James '67C 2
Jerry 5TJ Posted December 27, 2021 Report Posted December 27, 2021 On 11/6/2021 at 7:45 PM, Oscar Avalle said: This is how I have mine installed. I am just having difficulties calibrating it. I had a fair amount of trouble with calibration of the system. Ultimately it took 5 test flights. Alpha Systems was very supportive. They lent me a test set to confirm all the wiring and pneumatic connections were good. That helped greatly as I then knew that getting the vane angle set was the remaining issue. Once the proper vane angle is found the calibration took us (definitely take a second pilot along!) perhaps 30 minutes. I chose to have the system use 4 configurations: Flaps up, gear up Flaps up, gear down Half flaps, gear down Full flaps, gear down That means eight configuration entries (plus 4 more for the optional Vs x 1.1 settings) for calibration. 2
carusoam Posted December 30, 2021 Report Posted December 30, 2021 Inviting @201er to the conversation… (positive AOAi discussion…) Question for @Jerry 5TJ… when using your Alpha AOA system… does it know the current configuration? How do you know you are reading the correct indication for the current configuration? My fear… a small amount of stress, I may make a mistake reading the flaps up/down triangles of the other dual configuration systems… Best regards, -a-
Jerry 5TJ Posted December 30, 2021 Report Posted December 30, 2021 7 hours ago, carusoam said: Inviting @201er to the conversation… (positive AOAi discussion…) Question for @Jerry 5TJ… when using your Alpha AOA system… does it know the current configuration? We installed the system using the Aloha Systems interface module to take inputs on gear and flap positions. So, yes, the AoA computer knows which of the four configurations to use in calculating the display The pilot sees a display of AoA appropriate for the current configuration.
