Derek Posted August 25, 2021 Report Posted August 25, 2021 I finally did it. I backed up into a static wick. Fortunately it happened while briefing a passenger, so at least I got the l embarrassment over right away. But, which part on here is the one I need to order? And then, from where? It felt good to crack open the parts manual for the first time and figure out how to use it to find the right page. But, when I got there... "Now what?" Thanks!
Guest Posted August 25, 2021 Report Posted August 25, 2021 You may need the wick and the base. The stud is a 4-40 stainless steel piece, if it’s broken off in the base they’re almost impossible to drill out. Clarence
Derek Posted August 25, 2021 Author Report Posted August 25, 2021 Thanks @M20Doc, I'll have a look this weekend and see if I'll need to get the base too. Anyone know where I can buy a 10-900 60/1 wick? Lasar is sold out: https://lasar.com/pitot-static-system/static-wickstatic-discharger-10-900-601
PilotX Posted August 25, 2021 Report Posted August 25, 2021 Look on SkyGeek. I was looking for the base and the wicks for mine.
StevenL757 Posted August 25, 2021 Report Posted August 25, 2021 Aviall also has them, if you're authorized to purchase from them. They usually have stock. ~$55 or so + shipping & tax.
Derek Posted August 25, 2021 Author Report Posted August 25, 2021 Aviall also has them, if you're authorized to purchase from them. They usually have stock. ~$55 or so + shipping & tax.Looks like they're out, but thanks!Sent from my Pixel 3 XL using Tapatalk
PT20J Posted August 25, 2021 Report Posted August 25, 2021 Usually the black conductive plastic part breaks. However, I learned that they can also vibrate loose and disappear during flight, so I’ve tightened them and check them periodically. I got mine from LASAR. Skip
StevenL757 Posted August 25, 2021 Report Posted August 25, 2021 1 hour ago, Derek said: Looks like they're out, but thanks! Ugh... Wow, that's a first.
PT20J Posted August 25, 2021 Report Posted August 25, 2021 If you have the parts and the plastic broke, you can put superglue on the break and apply heat shrink tubing over it to hold it together. It may not be as effective, but one repaired one won't make any difference and you can replace it later. Skip
PJClark Posted August 25, 2021 Report Posted August 25, 2021 It's the one labeled "DD-1W" in the parts list. I just bought some from Sky Geek. For an extra $5 each you can get them "certified". I bought some of each, they're the same part number, and as near as I can tell there's no difference at all. I dropped them all by accident, got them all jumbled up so I'm not sure which ones got installed on my airplane... 2
MooneyMitch Posted August 25, 2021 Report Posted August 25, 2021 9 hours ago, PT20J said: Usually the black conductive plastic part breaks. However, I learned that they can also vibrate loose and disappear during flight, so I’ve tightened them and check them periodically. I got mine from LASAR. Skip Hmmm..... I wondered what that thing was that stuck in my front yard recently!! 1
PT20J Posted August 26, 2021 Report Posted August 26, 2021 1 hour ago, PJClark said: It's the one labeled "DD-1W" in the parts list. I just bought some from Sky Geek. For an extra $5 each you can get them "certified". I bought some of each, they're the same part number, and as near as I can tell there's no difference at all. I dropped them all by accident, got them all jumbled up so I'm not sure which ones got installed on my airplane... Mooney used a couple of different types. The TCO DD-1W is available on Sky Geek but it doesn't match the OP's SPECMAT 10-900-60/1. Aviall sells the SPECMATs (but not retail) and LASAR was the only place I found that stocked them. Maybe someone else has a retail source., Skip
Guest Posted August 26, 2021 Report Posted August 26, 2021 7 minutes ago, PT20J said: Mooney used a couple of different types. The TCO DD-1W is available on Sky Geek but it doesn't match the OP's SPECMAT 10-900-60/1. Aviall sells the SPECMATs (but not retail) and LASAR was the only place I found that stocked them. Maybe someone else has a retail source., Skip They seem to be hard to find at the moment. My wife recently bought some from Aviall, but not enough for our needs. Just another example of supply issues. Clarence
Derek Posted August 30, 2021 Author Report Posted August 30, 2021 My local MSC has a few in stock. I can share details if anyone needs.
RoundTwo Posted March 29, 2024 Report Posted March 29, 2024 Bringing this topic back to life because a tragic parking incident resulted in a broken base. My plane used the DD-1W wick and the TCO B-1 base. I’ve spoken directly to TCO and the B-1 bases are no longer available. Has anyone else had to find an alternate and if so, what did you use?
