FlyBoyM20J Posted April 23, 2021 Report Posted April 23, 2021 I always check the lights during preflight and one day last week, no strobes. The day before, they were fine. I got a chance to look at this today and the voltage coming out of the Klixon breaker is > 12V, and the power reaching each of the Hoskins strobe PSs in the wings is > 12V. The B+ wire for the right-hand strobe measures around +500V DC and the B+ wire for the left-hand strobe is about +470V DC. Nothing on the Trig lines going to either strobe tube, and nothing on the SYNC line coming into either PS. GND is good at PS inputs and at strobe molexes. No tail strobe light on this plane, but the strobe PS is in the tail cone. Didn't measure anything at it but nothing looks amiss looking from the vicinity of the battery. Is it possible that *both* of my strobe tubes died at the same time? Or does one dead tube inhibit the other PS via the SYNC line? Cliff Pic of a PS in the wing (both are same): Quote
N201MKTurbo Posted April 23, 2021 Report Posted April 23, 2021 Disconnect the sync line and see what happens. 1 Quote
FlyBoyM20J Posted April 23, 2021 Author Report Posted April 23, 2021 This is what is in the maintenance manual...so...likely a bad Hoskins PS that can be isolated by disconnecting SYNC as N201MKTurbo suggests? Quote
FlyBoyM20J Posted April 23, 2021 Author Report Posted April 23, 2021 Just now, EricJ said: Time for LEDs! Has anybody done this with Lasar wing farings? I have those on this plane.... Quote
FlyBoyM20J Posted April 23, 2021 Author Report Posted April 23, 2021 I found this, so I guess I can fix the broken PS (thanks NicoN!), but I'm leaning toward LEDs at this point... Cliff Quote
carusoam Posted April 24, 2021 Report Posted April 24, 2021 While leaning one way or the other... We can invite our Whelen guy to see if he has any suggestions... @OSUAV8TER Best regards, -a- 1 Quote
KB4 Posted April 24, 2021 Report Posted April 24, 2021 Chances are holes that come with mounting plate won’t line up cause the lightening hole. May need a filler with nut plate attached. 1 Quote
OSUAV8TER Posted April 26, 2021 Report Posted April 26, 2021 @FlyBoyM20J Cliff, if you're looking to go to LED I have the Orion 650E for $479.99 a side (Spruce sells them for $526 a side. Generally you can repurpose your existing wiring but I don't believe there is much support for the old Hoskins units, at least that is my impression. Give me a should if you are interested in this. https://www.gallagheraviationllc.com/whelen-aircraft-lighting.html ← My website1-833-425-5288 ← Call megallagheraviationllc@gmail.com ← Email me 1 Quote
mooney2201 Posted April 27, 2021 Report Posted April 27, 2021 I may have the Hoskins controllers.. I switched to led strobes And yes one bad strobe will knock out the other.. Give me a phone number and I will call you tomorrow and let you know that I have all the parts you need 1 Quote
FlyBoyM20J Posted April 29, 2021 Author Report Posted April 29, 2021 On 4/26/2021 at 8:21 AM, OSUAV8TER said: @FlyBoyM20J Cliff, if you're looking to go to LED I have the Orion 650E for $479.99 a side (Spruce sells them for $526 a side. Generally you can repurpose your existing wiring but I don't believe there is much support for the old Hoskins units, at least that is my impression. Give me a should if you are interested in this. https://www.gallagheraviationllc.com/whelen-aircraft-lighting.html ← My website1-833-425-5288 ← Call megallagheraviationllc@gmail.com ← Email me This looks perfect! I have the same wing tip extensions/fairings...Will check website, but I'm assuming that the way to wire these LEDs would be to bypass the Hoskins units in the wings...would be nice to remove them but they don't seem to cause much of a problem. Cliff Quote
FlyBoyM20J Posted April 29, 2021 Author Report Posted April 29, 2021 On 4/27/2021 at 12:20 AM, mooney2201 said: I may have the Hoskins controllers.. I switched to led strobes And yes one bad strobe will knock out the other.. Give me a phone number and I will call you tomorrow and let you know that I have all the parts you need Thank you! I am away from my plane for a few days...back at it next week, and if I decide to stay with Xenon tubes and Hoskins, I'd be grateful for a working Hoskins unit. I'll dm you my phone number at that point...don't want to make you dig through your parts unless I'm going that route. Cliff Quote
OSUAV8TER Posted April 29, 2021 Report Posted April 29, 2021 4 hours ago, FlyBoyM20J said: This looks perfect! I have the same wing tip extensions/fairings...Will check website, but I'm assuming that the way to wire these LEDs would be to bypass the Hoskins units in the wings...would be nice to remove them but they don't seem to cause much of a problem. Cliff @FlyBoyM20J everything Hoskins gets removed. The old lights and the strobe power supplies are removed for installation. You can repurpose your existing wiring and the Orion 650E power is self contained. Hook up the right wiring and they work. Again, the strobe power supplies have to be removed. If you have a 14V electrical system the model numbers are OR6501RE and OR6501GE and if you have a 28V electrical system the model numbers are OR6502RE and OR6502GE. They are $479.99 a side. 1 Quote
FlyBoyM20J Posted April 29, 2021 Author Report Posted April 29, 2021 1 hour ago, OSUAV8TER said: @FlyBoyM20J everything Hoskins gets removed. The old lights and the strobe power supplies are removed for installation. You can repurpose your existing wiring and the Orion 650E power is self contained. Hook up the right wiring and they work. Again, the strobe power supplies have to be removed. If you have a 14V electrical system the model numbers are OR6501RE and OR6501GE and if you have a 28V electrical system the model numbers are OR6502RE and OR6502GE. They are $479.99 a side. This sounds perfect...is the STC included? Cliff Quote
OSUAV8TER Posted April 29, 2021 Report Posted April 29, 2021 5 minutes ago, FlyBoyM20J said: This sounds perfect...is the STC included? Cliff @FlyBoyM20J these are not STC approved for the M20J but the pathway to installation is a minor alteration with a logbook entry. The lights are FAA TSO approved as an anti-collision and night position light system. Most lighting companies are moving way from STCs, getting them TSO approved, and are having customers install them as a minor alteration. Your A&P has to sign off on this. 1 Quote
carusoam Posted April 30, 2021 Report Posted April 30, 2021 Great detailed support OSU! Go MS! Best regards, -a- 1 Quote
