On 11/17/2020 at 9:59 AM, larrynimmo said:
when I went to remove the grease fitting from the MLG zerk, the pressed in zerk actually pulled out...the bearing base appears to be a brass body, and I was able to tap the zerk back in...it stayed in...from now on I will be using the release lever type of grease fitting when I grease or bust these more delicate zerks
My MLG front trunion press-in zerks pull out as well. Has anyone tried oversizing the "drive-in zerk" hole and tapping to a regular 1/4" screw in?
