PT20J Posted May 30, 2020 Report Posted May 30, 2020 I pulled the interior out for refurbishment and noticed some minor surface corrosion. This surprised me since the later models have the epoxy primer coated tubes and closed cell foam insulation and the windows don't leak and the airplane has always been hangared. The problem is that the primer only works if it is applied to all the bare metal and the factory obviously missed spraying it into the gusseted areas. I cleaned it up and brush applied three coats of epoxy primer. Below are photos and a drawing showing where I found the corrosion. Areas along the tubes outside the gussets that appear stained just have glue residue from the interior installation - no rust. Skip tubular structure_20200530_0001.pdf 3 Quote
MooneyMitch Posted May 30, 2020 Report Posted May 30, 2020 Did you use Dremel tool to reach the inner areas of the joints? Quote
PT20J Posted May 30, 2020 Author Report Posted May 30, 2020 2 hours ago, MooneyMitch said: Did you use Dremel tool to reach the inner areas of the joints? I had some .010 stainless steel sheet kicking around and I cut a piece about 3/8" x 4" and glued some 150 grit aluminum oxide sandpaper to it to get into the crevices. I also used a small wire brush. 3 Quote
jetdriven Posted May 31, 2020 Report Posted May 31, 2020 I have seen a little bit of rust in the gusset in the area right below the baggage door. I think the baggage door seal leaks occasionally, the water finds its way there and it sits in a pool, it cannot drain. Brush it with some corroseal and replace the baggage door seal. Quote
Stephen Posted May 31, 2020 Report Posted May 31, 2020 Might be a little rust on the gusset, but don't let it fool ya bout what's inside. Quote
PT20J Posted May 31, 2020 Author Report Posted May 31, 2020 You get corrosion inside the tubes if water gets in there. This generally happens when there is a window leak that allows water to collect and rust out the PK screws that are screwed into the tubes in a few locations to mount the interior panel attachment brackets. The water gets in the holes and runs downhill and rusts the inside of the bottom tubes where it collects. The most common leak is the pilot storm window. All the PK screws should be sealed. Skip 1 Quote
bradp Posted June 1, 2020 Report Posted June 1, 2020 Skip what epoxy did you use? mine is all zinc chromate - so last time it was bunch of PPE in the hazmat can. Quote
PT20J Posted June 1, 2020 Author Report Posted June 1, 2020 38 minutes ago, bradp said: Skip what epoxy did you use? mine is all zinc chromate - so last time it was bunch of PPE in the hazmat can. I don't know. I went to the museum on my field that does a lot of paint work and they mixed me up a cup of their favorite epoxy primer for painting tubes. It's similar to the factory primer in that it has a semi-gloss finish which makes it less porous than most primers. It's probably not the best primer for painting over but good if you are going to leave it exposed. Skip Quote
larrynimmo Posted June 1, 2020 Report Posted June 1, 2020 This gives me a lot to look for when I redo my interior of my 1981 m20j....everywhere I have removed panels, I have seen light surface corrosion on my tubing...worse than yours, but not terrible...all of my tubing has been coated several times with a zinc chromate paint..I typically clean it up well with sandpaper and scotchbrite, and then I paint it..hopefully I can significantly retard the progress. Quote
