PilotFun101 Posted May 29, 2020 Report Posted May 29, 2020 Consider Subscribing and Fly Along! It was a long but fun process replacing all my analogue instruments with digital avionics. After 3 months in the shop it was time to #FlyDynon. This is my first time sharing my experience flying the Dynon SkyView HDX on film. Check out the in-flight review. Join me in my MooneyM20C Ranger as we fly around the North East. Thanks for Flying Along! Proudly Sponsored By: Special Thank You to - Moyer Aviation http://www.moyeraviation.com/ Bose Aviation - https://www.bose.com/en_us/products/h... Proud Partners: Special Thank You to Dynon Avionics - https://www.dynonavionics.com/ (Best All-In-One System) Elevation Adventures Flight School - https://www.elevation-adventures.com/ Use Promotion Code PilotFun101 for 10% off all courses!! GoPro - https://gopro.com/en/us/ (HERO 5 & 7) Foreflight - https://foreflight.com/ My Favorite Aviation App for Pilots Aviation Oil Outlet - https://aviationoiloutlet.com/ Best prices for pilots (FREE SHIPPING) E-mail - PilotFun101@gmail.com Follow me - Facebook - https://www.facebook.com/PilotFun101/ Instagram - https://www.instagram.com/pilotfun101/ Transponder - Lynx L3 - https://www.l-3lynx.com/ Best All-In-One transponder for pilots. GPS - Avidyne IFD540 - https://www.avidyne.com/ Check out aviation fun stuff on Amazon https://www.amazon.com This Video is for entertainment purposes only and is not to be considered flight instruction in any way. Please contact your local CFI for flight instruction. #DynonCertifited #Mooney #PanelUpgrade 1 Quote
gsxrpilot Posted May 29, 2020 Report Posted May 29, 2020 Love the video and the Dynon looks great. You say at the beginning that the Mooney cockpit is an inch smaller than most other airplanes. Maybe I misunderstood, but let's not propagate the myth that Mooney cockpits are narrower than other comparable airplanes. The seating position is lower, there is no room under the seat like there is in a Cessna, etc. But the Mooney cockpit is actually wider than other comparable airplanes. And you're probably sitting closer to the panel than in other airplanes. But the Mooney is wider... Cessna 150 38 inches Cessna 172 and 152 40 inches Grumman AA5 41 inches Cessna 182 42 inches Piper PA28 42 inches Bonanzas 42 inches Cessna 206/210 has 43 inches Mooney cabin is 43.5 inches 5 Quote
flyboy0681 Posted May 29, 2020 Report Posted May 29, 2020 35 minutes ago, gsxrpilot said: Love the video and the Dynon looks great. You say at the beginning that the Mooney cockpit is an inch smaller than most other airplanes. Maybe I misunderstood, but let's not propagate the myth that Mooney cockpits are narrower than other comparable airplanes. The seating position is lower, there is no room under the seat like there is in a Cessna, etc. But the Mooney cockpit is actually wider than other comparable airplanes. And you're probably sitting closer to the panel than in other airplanes. But the Mooney is wider... Cessna 150 38 inches Cessna 172 and 152 40 inches Grumman AA5 41 inches Cessna 182 42 inches Piper PA28 42 inches Bonanzas 42 inches Cessna 206/210 has 43 inches Mooney cabin is 43.5 inches Conspicuously left out the Rockwell Commander? 1 Quote
gsxrpilot Posted May 29, 2020 Report Posted May 29, 2020 Just now, flyboy0681 said: Conspicuously left out the Rockwell Commander? And Cirrus Quote
flyboy0681 Posted May 29, 2020 Report Posted May 29, 2020 Just now, gsxrpilot said: And Cirrus With all due respect, I thought you were only listing metal planes, so you are good. 1 Quote
PilotFun101 Posted May 29, 2020 Author Report Posted May 29, 2020 1 hour ago, gsxrpilot said: Love the video and the Dynon looks great. You say at the beginning that the Mooney cockpit is an inch smaller than most other airplanes. Maybe I misunderstood, but let's not propagate the myth that Mooney cockpits are narrower than other comparable airplanes. The seating position is lower, there is no room under the seat like there is in a Cessna, etc. But the Mooney cockpit is actually wider than other comparable airplanes. And you're probably sitting closer to the panel than in other airplanes. But the Mooney is wider... Cessna 150 38 inches Cessna 172 and 152 40 inches Grumman AA5 41 inches Cessna 182 42 inches Piper PA28 42 inches Bonanzas 42 inches Cessna 206/210 has 43 inches Mooney cabin is 43.5 inches Thank you @gsxrpilot for the information! Still learning. 1 Quote
elimansour Posted May 29, 2020 Report Posted May 29, 2020 What a fantastic video and a great demo of the Dynon system. Really looks to be a very capable system and easy to use. 1 Quote
PilotFun101 Posted May 29, 2020 Author Report Posted May 29, 2020 6 minutes ago, elimansour said: What a fantastic video and a great demo of the Dynon system. Really looks to be a very capable system and easy to use. Thank you! Quote
carusoam Posted May 29, 2020 Report Posted May 29, 2020 Nice work again, 101... +1 on killing the wydth myth... Knots would be good... but all your POH numbers are in mph... I like the altitude call outs... Use caution... ADSB data age can be misleading... It is a two step process... data gathering and compilation... you are probably getting the compilation time... compiled a bunch of 10minute old data... the total lag time isn’t being Properly being delivered to you... (something you can do the research on as your system may be improved compared to mine) Best regards, -a- 1 Quote
PilotFun101 Posted May 30, 2020 Author Report Posted May 30, 2020 15 hours ago, carusoam said: Nice work again, 101... +1 on killing the wydth myth... Knots would be good... but all your POH numbers are in mph... I like the altitude call outs... Use caution... ADSB data age can be misleading... It is a two step process... data gathering and compilation... you are probably getting the compilation time... compiled a bunch of 10minute old data... the total lag time isn’t being Properly being delivered to you... (something you can do the research on as your system may be improved compared to mine) Best regards, -a- Thank you @carusoam and thanks for the info. 1 Quote
Oscar Avalle Posted June 6, 2020 Report Posted June 6, 2020 On 5/29/2020 at 11:49 AM, gsxrpilot said: Love the video and the Dynon looks great. You say at the beginning that the Mooney cockpit is an inch smaller than most other airplanes. Maybe I misunderstood, but let's not propagate the myth that Mooney cockpits are narrower than other comparable airplanes. The seating position is lower, there is no room under the seat like there is in a Cessna, etc. But the Mooney cockpit is actually wider than other comparable airplanes. And you're probably sitting closer to the panel than in other airplanes. But the Mooney is wider... Cessna 150 38 inches Cessna 172 and 152 40 inches Grumman AA5 41 inches Cessna 182 42 inches Piper PA28 42 inches Bonanzas 42 inches Cessna 206/210 has 43 inches Mooney cabin is 43.5 inches I believe the issue is how difficult (compared to others) it is to get into our seats. Once you are in, it is great. 1 Quote
