RobertGary1 Posted October 9, 2019 Report Posted October 9, 2019 My Concorde was getting weak. My tester computed it at 100cca. So I put it on my regen for 48 hours and then afterwards charged it. Flew with it and then the plane sat for 2 weeks. On the next start it paused at the first compression but then spun like a top. Ever since it’s been working far better. So I’m not sure if it’s necessary to buy an Aviation regen system as the automotive seemed to work well. I’ll probably run a regen on it annually. -Robert 2 Quote
RLCarter Posted October 9, 2019 Report Posted October 9, 2019 I agree, all I've ever used is a standard Schumacher battery charger and not a big fan of smart chargers either Quote
Shiny moose Posted October 9, 2019 Report Posted October 9, 2019 40 minutes ago, RobertGary1 said: My Concorde was getting weak. My tester computed it at 100cca. So I put it on my regen for 48 hours and then afterwards charged it. Flew with it and then the plane sat for 2 weeks. On the next start it paused at the first compression but then spun like a top. Ever since it’s been working far better. So I’m not sure if it’s necessary to buy an Aviation regen system as the automotive seemed to work well. I’ll probably run a regen on it annually. -Robert So what brand/ model are you using Quote
Hank Posted October 9, 2019 Report Posted October 9, 2019 I'm on my third year with Concorde #2, still going strong (replaced #1 preemptively at six and a half years before flying into the hinterlands). All I've ever done is drop them in that black bix in the firewall and fly every niw and again--not near enough, and certainly not every week. YMMV, etc. Quote
jetdriven Posted October 9, 2019 Report Posted October 9, 2019 the concorde manual shows how to do a capacity test, my first RG35AXC lasted 7 years. This one, 14 months. its 22% capacity. Quote
Steve W Posted October 9, 2019 Report Posted October 9, 2019 1 hour ago, jetdriven said: the concorde manual shows how to do a capacity test, my first RG35AXC lasted 7 years. This one, 14 months. its 22% capacity. And it also shows how to do a Conditioning charge, but 22% may be beyond help. Quote
LANCECASPER Posted October 9, 2019 Report Posted October 9, 2019 9 hours ago, jetdriven said: the concorde manual shows how to do a capacity test, my first RG35AXC lasted 7 years. This one, 14 months. its 22% capacity. It's suffering from a case of Gill-itis. Quote
RobertGary1 Posted October 9, 2019 Author Report Posted October 9, 2019 This is what I used. It something I keep around for boat batteries, motorcycle, etc. It seems to have done well with my Concorde too. https://www.amazon.com/gp/product/B01BYFSUJW/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1 -Robert 1 Quote
lotsofgadgets Posted October 9, 2019 Report Posted October 9, 2019 Kitplanes magazine ran an article last year reviewing an inexpensive Harbor Freight charger. To quote the author "But when a $40 product1 from Harbor Freight saves me a $300 battery, it is worth writing about". I have used the same charger on my Concorde and on golf cart/rv batteries with good success https://www.kitplanes.com/aero-lectrics-66/ 1 Quote
GeeBee Posted October 9, 2019 Report Posted October 9, 2019 You have to be careful with "Battery Reconditioning" modes. Some chargers use higher voltage to de-sulphate the battery plates. In AGM batteries high charge voltages can permanently damage the battery unless the voltage spikes are sent in pulses of 22-28 kHz. If your charger has an AGM mode and a reconditioning mode you are good to go, otherwise check the manual of the charger. Quote
