timj0rdan86 Posted August 2, 2019 Report Share Posted August 2, 2019 hi everyone I own 67 M20F it recently went down for annual and the flange for the induction tube was damaged, so I contacted Lycoming and they sent me a new pipe which superseded the previous part. this new tube appears to long. Any tips for installation, modifications, etc thanks Quote Link to comment Share on other sites More sharing options...
timj0rdan86 Posted August 2, 2019 Author Report Share Posted August 2, 2019 DOES ANY HAVE A PDF OF THE SERVICE MANUAL FOR THIS MODEL Quote Link to comment Share on other sites More sharing options...
Shadrach Posted August 2, 2019 Report Share Posted August 2, 2019 PM me your email address Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted August 2, 2019 Report Share Posted August 2, 2019 It looks right to me. you should be able to stick it in place without an o ring and easily check the fit. Quote Link to comment Share on other sites More sharing options...
PT20J Posted August 2, 2019 Report Share Posted August 2, 2019 4 hours ago, timj0rdan86 said: DOES ANY HAVE A PDF OF THE SERVICE MANUAL FOR THIS MODEL www.lycoming.com Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 6, 2019 Report Share Posted August 6, 2019 How damaged was the flange? Looks pretty easy to fix using some metal working tools, and a mechanic? aside from that... got a CO monitor for your plane? In case the new exhaust bits don’t quite seal properly... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted August 6, 2019 Report Share Posted August 6, 2019 On 8/2/2019 at 11:18 AM, timj0rdan86 said: DOES ANY HAVE A PDF OF THE SERVICE MANUAL FOR THIS MODEL What you really want is the parts manual. The service manual tells you how to take it apart and put it back together. The parts manual has all the drawings and part numbers. Quote Link to comment Share on other sites More sharing options...
