1 hour ago, AlexLev said:
Embarrassing update: wanted to re-torque the bolts after the A&P bolted on the exhaust (after flying it) and instead of using 150 in lbs, used 150 ft lbs and broke off on the left rear exhaust stack/riser. Hope someone learns from my mistake.
@Shadrach or @M20Doc: curious if you have any ideas for how to work that out without damaging the cylinder? I'll be working with an A&P as well, but wondering if any of you have any experience on working that remaining stud out. I feel really dumb :(
See pics:
868919249_ScreenShot2019-04-01at7_36_19PM.thumb.png.c9e31a18aebe54e49b3c86fddc6aef99.png
It looks like there is enough of the stud remaining to extract it.  Pull the exhaust riser and gasket to expose it.  Ask your maintainer if he has a Snap On stud extractor like this one.  It’s a collet style that you thread on to the stud, then tighten the collet to grip the stud.  The stud will be a 5/16-18 NC thread.
Turn the engine over until the valve is closed, heat the inside of the port with a propane torch and turn the stud out.
Edited by M20Doc
