I am not sure how the older HSI magnetometers were installed but it will probably be mounted in a wing to an inspection plate with the brass screws Anthony mentioned.
You may also find another set of screw heads on an inspection plate out near the wing tips if you have strobes. These will be on both sides. The magnetometer will be closer to mid wing.
