Can't see your picture . . .
Mine broke three years ago, it was fixed up and welded back together. Couldn't understand why my climb rate sucked leaving NC mountains or where my cruise speed went . . . . . It just doesn't run well with carb neat fully open all the time!
I'll see if I can find a picture for you.
Call Dan in the LASAR parts department. Email him your picture and he'll send you the right part.  If you have time to wait, they can probably repair yours.
2 hours ago, Boilermonkey said:
Sent from my SM-G960U using Tapatalk
Yep, that's where mine broke. My A&P welded it up. It's not pretty, but it's functional. Put in a new cable, too. Twas a pricey annual (failure happened three weeks before it started, giving me time to d!ck around with it and figure out why I had little climb and no speed . . . . ).
5 hours ago, orionflt said:
You can pull it apart and have it welded
Brian
That's what I did. Works great! Almost three years ago.
+1 Really important to have working properly...
Mine broke the control wire... stress, fatigue and corrosion... the wire , not me... :)
Good luck with sourcing the parts...
27 minutes ago, DXB said:
Mooney had the part in stock when mine broke.  Also I bet McFarlane will make one for you
Found one in salvage, hoping it is in as good condition as they say.  We'll probably get a spare or new one in the near future.  Some of the parts for our 1962 M20C  are near impossible to find...otherwise there's going to be a lot of minor/major forms that we'll need to start filing.
