isaacpr7 Posted January 21, 2018 Report Posted January 21, 2018 I've had a prop seal leak for some time but not bad enough that it was a concern. I had it replaced last week because I'm flying at night more often and I could not see clearly during landings because of the thin oily film on the windshield. After it was replaced I flew the aircraft a few days later on a 9 hour cross country. During the first 4.5 hours I didn't notice any leaks. On my way back I noticed it began to leak and by the time I put her to bed I noticed the seal was there again. Has this happened to anyone before? Thoughts? Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
N201MKTurbo Posted January 21, 2018 Report Posted January 21, 2018 Are you talking about the front crankshaft seal, the o ring on the prop flange or the prop blades? Quote
isaacpr7 Posted January 22, 2018 Author Report Posted January 22, 2018 Are you talking about the front crankshaft seal, the o ring on the prop flange or the prop blades? Yes, the crankshaft seal O ring.Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
TheTurtle Posted January 22, 2018 Report Posted January 22, 2018 let us know what you find. Im supposed to change mine next month. really dont want to take the prop off twice Quote
Yetti Posted January 22, 2018 Report Posted January 22, 2018 taking proper care to not hurt yourself.... you can feel the seal with one finger then move the prop with the other and see if it spins. If it does you need to redo it. 1 Quote
Yetti Posted January 22, 2018 Report Posted January 22, 2018 I had a leak that I thought was the crank seal, but was the drain back hose on the cylinder head. They need to be tightened ever so often, but the oil usually goes down, no up on the wind screen Quote
carusoam Posted January 22, 2018 Report Posted January 22, 2018 There is a split replacement seal that can be applied without having to take the prop off... But something seams to have ruined two seals already..? The prop shaft seal is only keeping the splashed oil from getting out. It isn't seeing much pressure... Make sure we are discussing the same thing.... Best regards, -a- 1 Quote
Yetti Posted January 22, 2018 Report Posted January 22, 2018 From the grumpy IA. The last one may have spun for awhile and oversized the case. They make an oversized seal for that application 2 Quote
isaacpr7 Posted January 22, 2018 Author Report Posted January 22, 2018 taking proper care to not hurt yourself.... you can feel the seal with one finger then move the prop with the other and see if it spins. If it does you need to redo it. Did what you suggested and it did not spin. The left side was pretty dry but the right side was very wet.Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
isaacpr7 Posted January 22, 2018 Author Report Posted January 22, 2018 There is a split replacement seal that can be applied without having to take the prop off... But something seams to have ruined two seals already..? The prop shaft seal is only keeping the splashed oil from getting out. It isn't seeing much pressure... Make sure we are discussing the same thing.... Best regards, -a- It's the seal behind where the prop attaches to. It has a spring that is installed in it. I'm beginning to suspect that maybe there's another source. I'll wash the area down really good and fly her to the MX to try pin pointing the source. Sent from my SAMSUNG-SM-G930A using Tapatalk 1 Quote
isaacpr7 Posted January 22, 2018 Author Report Posted January 22, 2018 From the grumpy IA. The last one may have spun for awhile and oversized the case. They make an oversized seal for that application Thanks for the suggestion Yetti. I'll bring that up to the MX.Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
isaacpr7 Posted January 22, 2018 Author Report Posted January 22, 2018 These pics are terrible and you can't see the oil well enough because of the flash but here they are. I also can't take a pic directly of the seal.Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
carusoam Posted January 22, 2018 Report Posted January 22, 2018 Great photos! Maybe @M20Doc can see something there or offer advice...? Best regards, -a- 1 Quote
Guest Posted January 22, 2018 Report Posted January 22, 2018 8 hours ago, isaacpr7 said: These pics are terrible and you can't see the oil well enough because of the flash but here they are. I also can't take a pic directly of the seal. Sent from my SAMSUNG-SM-G930A using Tapatalk From your first picture, the inside of the ring gear support does not appear to be wet with oil?? A leaking crankshaft seal will usually leave oil in the support. Wash the engine down with some 100 LL and a blast of compressed air. Spray the area in question with some Arid Extra dry antiperspirant which leaves a dry white powder film behind and will help you find the source of the oil leak. Clarence Quote
Yetti Posted January 22, 2018 Report Posted January 22, 2018 The O ring on the shaft may have got nicked when the prop was put back on..... Quote
isaacpr7 Posted January 23, 2018 Author Report Posted January 23, 2018 From your first picture, the inside of the ring gear support does not appear to be wet with oil?? A leaking crankshaft seal will usually leave oil in the support. Wash the engine down with some 100 LL and a blast of compressed air. Spray the area in question with some Arid Extra dry antiperspirant which leaves a dry white powder film behind and will help you find the source of the oil leak. Clarence Awesome! I will give that a shot. Thanks a bunch.Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
isaacpr7 Posted March 29, 2018 Author Report Posted March 29, 2018 From your first picture, the inside of the ring gear support does not appear to be wet with oil?? A leaking crankshaft seal will usually leave oil in the support. Wash the engine down with some 100 LL and a blast of compressed air. Spray the area in question with some Arid Extra dry antiperspirant which leaves a dry white powder film behind and will help you find the source of the oil leak. Clarence I sprayed Arid as you suggested and it worked like a charm The leak is coming from the prop seal still. I will be ordering the oversized seal. Do you know what the oversized seal part number is by any chance?Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
