MARZ Posted December 22, 2017 Report Posted December 22, 2017 Got a new camera for my birthday - Pretty impressive at 1080 - next go will be at 4k (make sure to change the resolution when it plays - for some reason when I pull up the video it defaults to a lower resolution) 6
DanM20C Posted December 22, 2017 Report Posted December 22, 2017 Is that just the built in image stabilization or is it mounted to a gimbal? The stabilization is impressive. Cheers, Dan
MARZ Posted December 23, 2017 Author Report Posted December 23, 2017 That’s the built in stabilization heres the mount 2
Baxsie Posted December 24, 2017 Report Posted December 24, 2017 Nice video. With that stabilization, I think that it would be cool if you could mount it on the tail, looking over the plane. Kind of a 3rd person view.
kris_adams Posted December 24, 2017 Report Posted December 24, 2017 Nice! I’m hoping to get one for Christmas!!
eman1200 Posted December 24, 2017 Report Posted December 24, 2017 does it come with a waterproof type plastic case? reason I ask is it looks like the camera is exposed to the elements, wonder if you'd want to protect it in a case if you're going to mount it outside.
mooneyman Posted December 24, 2017 Report Posted December 24, 2017 40 minutes ago, eman1200 said: does it come with a waterproof type plastic case? reason I ask is it looks like the camera is exposed to the elements, wonder if you'd want to protect it in a case if you're going to mount it outside. The camera is waterproof. It doesn’t come with a case.
M016576 Posted December 25, 2017 Report Posted December 25, 2017 What did you use to hold that RAM mount onto the fuselage? 1
MARZ Posted December 27, 2017 Author Report Posted December 27, 2017 Stole an idea from here on the forum - took a RAM mount, drilled and tapped a thread for a 5/16 18 piece of all thread rod. That screws into the tie down location on the wing. I put a thin piece of rubber insulator in place to act as a "lock washer" 2
Raptor05121 Posted December 28, 2017 Report Posted December 28, 2017 11 hours ago, Mike Ropers said: Stole an idea from here on the forum - took a RAM mount, drilled and tapped a thread for a 5/16 18 piece of all thread rod. That screws into the tie down location on the wing. I put a thin piece of rubber insulator in place to act as a "lock washer" Be careful, by that definition it needs a logbook entry. I've read threads over on Facebook on a guy getting dinged on a ramp inspection because of a "permanent" drill method. On 12/23/2017 at 10:31 PM, Baxsie said: Nice video. With that stabilization, I think that it would be cool if you could mount it on the tail, looking over the plane. Kind of a 3rd person view. Like this?
Baxsie Posted December 28, 2017 Report Posted December 28, 2017 2 hours ago, Raptor05121 said: Like this? Yes! Did you make some videos with that setup? I thought that this mount with the super-stable camera that Mike Roper has would look pretty cool.
jonhop Posted December 28, 2017 Report Posted December 28, 2017 3 hours ago, Raptor05121 said: Be careful, by that definition it needs a logbook entry. I've read threads over on Facebook on a guy getting dinged on a ramp inspection because of a "permanent" drill method. It's not permanent... just reach under the wing and unscrew the mount and camera from the tie down / hoist point... easy day. 1
gsxrpilot Posted December 28, 2017 Report Posted December 28, 2017 4 hours ago, Raptor05121 said: Be careful, by that definition it needs a logbook entry. I've read threads over on Facebook on a guy getting dinged on a ramp inspection because of a "permanent" drill method. Do you make a log book entry every time you install or remove your tie down rings? It's exactly the same thing. I had the same set up on my C and went through a ramp check without any issues.
MIm20c Posted December 28, 2017 Report Posted December 28, 2017 I would think using the tie down attachment would be a great way to do it. Looks like a ram mount is going under the knife this weekend. 1
gsxrpilot Posted December 28, 2017 Report Posted December 28, 2017 6 minutes ago, MIm20c said: I would think using the tie down attachment would be a great way to do it. Looks like a ram mount is going under the knife this weekend. I used the GoPro tripod mount. That and a piece of all-thread, a couple of nuts, and you're good to go. But the truth is the GoPro sticky mounts are just too easy. So they're all I use anymore.
ragedracer1977 Posted December 28, 2017 Report Posted December 28, 2017 I've been debating using a sticky mount on top of the wing to get a cockpit view, however I'm wondering how much that would affect the airflow. A go pro on a mount isn't much smaller than my speed brakes. Thoughts?
Raptor05121 Posted December 28, 2017 Report Posted December 28, 2017 8 minutes ago, ragedracer1977 said: I've been debating using a sticky mount on top of the wing to get a cockpit view, however I'm wondering how much that would affect the airflow. A go pro on a mount isn't much smaller than my speed brakes. Thoughts? I've got ~40 hours of flying with GoPros all over. Doesnt affect my speed one bit.
MARZ Posted December 28, 2017 Author Report Posted December 28, 2017 @Raptor05121 guess I wasn't clear - I didn't drill and tap anything on the plane - the mod was to the go pro mount to allow it to screw into the tie down location.
mooneyman Posted December 28, 2017 Report Posted December 28, 2017 5 hours ago, ragedracer1977 said: I've been debating using a sticky mount on top of the wing to get a cockpit view, however I'm wondering how much that would affect the airflow. A go pro on a mount isn't much smaller than my speed brakes. Thoughts? We use this mount from nflightcam on the wingtip. Easy to install and considered a minor alteration https://www.nflightcam.com/collections/frontpage/products/nflightcam-ball-head-exterior-mount
carusoam Posted December 31, 2017 Report Posted December 31, 2017 MooneyMan... had you considered hiding the camera behind one of the many forward looking light lense areas? This comes to mind with all the modernization of LED lights and recog light options... The advantage would be the aerodynamics, and safety for the camera itself. Best regards, -a-
gsxrpilot Posted January 1, 2018 Report Posted January 1, 2018 2 hours ago, carusoam said: had you considered hiding the camera behind one of the many forward looking light lense areas? This comes to mind with all the modernization of LED lights and recog light options... The advantage would be the aerodynamics, and safety for the camera itself. That would really only work if the camera lens was on the end of a long fiber cable of some sort so the camera its self could be in the cockpit. It would work to put the lens into a light fixture, but the camera needs to be accessible for power, batteries, changing setting, accessing the memory card, etc. You wouldn't want to be pulling the wingtip lenses off the plane every time you use the camera. 1
mooneyman Posted January 1, 2018 Report Posted January 1, 2018 17 hours ago, carusoam said: MooneyMan... had you considered hiding the camera behind one of the many forward looking light lense areas? This comes to mind with all the modernization of LED lights and recog light options... The advantage would be the aerodynamics, and safety for the camera itself. Best regards, -a- I had not considered positioning the camera in the light lense area. It is an interesting idea but in addition to Rocket's comments above, you would only get a forward facing view and would likely lose some picture clarity. I was never keen on mounting something on the wing but I think in reality the aerodynamic impact is minimal. This Nflighcam mount is very sturdy and secure. It was just a matter of swithcing out for a 1/2 inch longer screw. We also like the view looking back at the plane. We have a forward facing camera with prop filter mounted inside on the glareshield. 1
ragedracer1977 Posted January 1, 2018 Report Posted January 1, 2018 tired the wing mount yesterday. Out at the wingtip. Posted elsewhere here but thought it fit in this thread as well. Hero4 in a case. As you can see, the mount swiveled a bit in flight. Need to crank it down a little tighter. 4
