Marauder Posted December 13, 2017 Report Posted December 13, 2017 Got an idea, not sure this will work but have seen an endless stream of troubleshooting help threads and then in some cases final resolution of the problem. Thought maybe if a thread was created that just tracked each individual problem and the final resolution, it could serve as a depository of noted problems and their resolutions. What I am proposing is that an owner can create a thread for help on a problem NOT USING THIS THREAD, rather in the forum and once it has been resolved, post the problem description, photos, resolution, etc. here. As an example; Problem: Momentary rough running engine that lasted for 6 seconds. EGT was noted to drop on one cylinder for 6 seconds 150 degrees and then cleared up. Resolution: Savvy Analysis suspects clogged injector. Injector removed and found to contain FOD. Problem resolved. If this idea works PLEASE DO NOT REPLY HERE, JUST POST YOUR PROBLEMS AND RESOLUTIONS! 1 Quote
