2 hours ago, M20Doc said:
Not so, Cirrus, Diamond and Mooney use an electric back up AI along with a G1000.
Exactly! No vacuum pump in the G1000 Mooneys. Richard Collins article on the Ovation GX back in 2005 highlighted that there was no vacuum pump in G1000 Mooneys.
5992efee4bc7a_ScreenShot2017-08-15at7_55_35AM.thumb.png.1ffac1eabfb99c389b8a842393643dd5.png
Pretty sure that the Cessna G-1000 also uses an electric AI.
I think Cessna has the vacuum backup. Probably certified the 1000 that way.
Nope, vacuum attitude. Low vacuum annunciation built into the G1000.
-Robert
Edited by RobertGary1
-Robert
It's likely the only airframe retaining a vacuum system with the G-1000.
The early G1000's (early 2000's ) in the Cessnas actually hide a full blow turn coordinator to power to KAP 140 autopilot before Garmin's autopilot was certified with the G1000. If you remove the PFD you see a full turn coordinator.
Flying the G1000 with the KAP 140 was a royal pain because the integration was poor. So much better with the Garmin autopilot.
-Robert
