TargetDriver Posted February 17, 2018 Report Posted February 17, 2018 Raged, Back 10 years ago I had graphics wrapped onto my Top Dragster (205mph) and was partners on a TAFC that we had wrapped on a carbon body. I've had my K model now for 2 years (but have now been deployed for 11 months so no flying) and although my paint is 10 years old and still looks new, I'd be up for some wrapping from you ! You get it figured out and hit me up ! Right now I'm in Northern CA but heading to OK possibly in the next 4 or 5 months. I've seen wraps that are hard to tell from amazing paint jobs by the unknowing public. I'm game ! Your work looks as nice as any I've ever seen (from your pics). 2
gsxrpilot Posted February 17, 2018 Report Posted February 17, 2018 I would also be very interested in a wrap from @ragedracer1977. Any idea what a ballpark number would be to wrap a Mooney?
ragedracer1977 Posted February 18, 2018 Author Report Posted February 18, 2018 I am going to wrap mine this year, at least a good part of it. I’m afraid to quote any kind of pricing right now, because I really don’t know how long it’s going to take. If I had to guess, it would be in the neighborhood of $5k 2 1
NJMac Posted February 18, 2018 Report Posted February 18, 2018 I am going to wrap mine this year, at least a good part of it. I’m afraid to quote any kind of pricing right now, because I really don’t know how long it’s going to take. If I had to guess, it would be in the neighborhood of $5k Put me on the list too. Ive always wanted a Porsche 911 to wrap chrome like this one. Lets do my plane this way. Sent from my SM-G930V using Tapatalk 1
aviatoreb Posted February 18, 2018 Report Posted February 18, 2018 2 hours ago, NJMac said: Put me on the list too. Ive always wanted a Porsche 911 to wrap chrome like this one. Lets do my plane this way. Sent from my SM-G930V using Tapatalk There is a company that wraps small airplanes like that. I looked into it as a possibility before I decided to go old school and paint.... Mostly they do experimental, esp Vans, but they can do your Mooney. My tks essentially made my airplane ineligible since you don't want any open seems at the leading edge. http://www.aircraftwraps.com/about.html 1 1
Hank Posted February 18, 2018 Report Posted February 18, 2018 4 hours ago, aviatoreb said: There is a company that wraps small airplanes like that. I looked into it as a possibility before I decided to go old school and paint.... Mostly they do experimental, esp Vans, but they can do your Mooney. My tks essentially made my airplane ineligible since you don't want any open seems at the leading edge. http://www.aircraftwraps.com/about.html Boy, a shiny chrome wrap would be so much easier than having to polish all that aluminum . . . . 2
SantosDumont Posted February 19, 2018 Report Posted February 19, 2018 I asked for a quote from aircraft wraps and they never responded. I got the feeling that they only do expirimentals.
gsxrpilot Posted February 19, 2018 Report Posted February 19, 2018 @ragedracer1977 put me on the list. Once you get a chance to do yours and work out the costs, let me know and I'll bring mine to you. 1
ragedracer1977 Posted February 23, 2020 Author Report Posted February 23, 2020 1 hour ago, chriscalandro said: What ever happened with this? I talked to the Scottsdale FSDO. They said no. And referenced an FAA memo that says hell no to wraps. Google search "faa guidance on vinyl wrap". First PDF that pops up. 1
chriscalandro Posted February 23, 2020 Report Posted February 23, 2020 (edited) It says the memorandum is not applicable to decals and logos. what if most of the exterior of the plane is a decal and graphics? Edited February 23, 2020 by chriscalandro
skykrawler Posted February 23, 2020 Report Posted February 23, 2020 Vinyl Covering Shrink Wraps on Exterior of Part 23 Airplanes, Gliders, Airships The FAA has issued a memo stating there are safety issues with the installation of vinyl covering shrink wraps on the exterior of airplanes, gliders, and airships that are not present with other exteriors such as paint and deicing boots. These issues include hazards that are major to catastrophic, so the installation by FAA Field Approval is not acceptable. Only Federal Aviation Administration (FAA) Type Certificate (TC), Amended Type Certificate (ATC), and Supplemental Type Certificate (STC) are acceptable for this installation. This memorandum is not applicable to vinyl decals or logos that are placed on limited areas of the fuselage or empennage. The following are safety concerns with the installation of vinyl shrink wrap coverings that must be evaluated by the applicant for any TC/ ATC/STC application: 1. Without proper engineering evaluation and/or tests, vinyl shrink wrap cannot be placed on any control surface or control surface tab: a. without conslderation of the effect on the flutter characteristics (whether the surface is mass balanced or not) and b. where that installation would change the existing clearance between adjacent surfaces with and without loading. 2. Scoring the skin of aircraft when cutting the vinyl sheets to fit, which can start cracks, particularly in pressurized aircraft. 3. Blocking of fuel vents, static ports, hinges, drain holes etc., making them inoperative or changing the airflow over static ports. 4. Use of an open flame from a blowtorch to apply the material. This is a concern around fuel tanks and vents, sensitive antennas, and especially on composite parts, which have cure temperatures well below the temperature of a blowtorch. 5. Covering required exterior aircraft markings and emergency exits. 6. Vinyl sheets losing adhesion on the surface or on rotating parts and jamming control surtaces or compromising engines. 7. Static build‐up causing electrical discharges in or around fuel tanks and causing radio/navigation interference. 8. Tinting of windows and windshields with transparent vinyl, which compromises the view of pilots. 9. The impact on removal of ice build‐up on critical surfaces. 10. Flammability of the material, including lightning strikes, and especially near engine exhausts and around engine nacelles. Flammability test specimens should be built‐up from the cowling/nacelle with the vinyl shrink wrap applied. 11. Peeling of the wrap from rain or hail. 12. Masking of cracks and corrosion in structure and skin. 13. Lifetime of a vinyl shrink wTap installation. How long before mandatory removal. 14. Effects of de‐ice fluids on the film.
NJMac Posted February 24, 2020 Report Posted February 24, 2020 1. Without proper engineering evaluation and/or tests, vinyl shrink wrap cannot be placed on any control surface or control surface tab: a. without conslderation of the effect on the flutter characteristics (whether the surface is mass balanced or not) and b. where that installation would change the existing clearance between adjacent surfaces with and without loading. 2. Scoring the skin of aircraft when cutting the vinyl sheets to fit, which can start cracks, particularly in pressurized aircraft. 3. Blocking of fuel vents, static ports, hinges, drain holes etc., making them inoperative or changing the airflow over static ports. 4. Use of an open flame from a blowtorch to apply the material. This is a concern around fuel tanks and vents, sensitive antennas, and especially on composite parts, which have cure temperatures well below the temperature of a blowtorch. 5. Covering required exterior aircraft markings and emergency exits. 6. Vinyl sheets losing adhesion on the surface or on rotating parts and jamming control surtaces or compromising engines. 7. Static build‐up causing electrical discharges in or around fuel tanks and causing radio/navigation interference. 8. Tinting of windows and windshields with transparent vinyl, which compromises the view of pilots. 9. The impact on removal of ice build‐up on critical surfaces. 10. Flammability of the material, including lightning strikes, and especially near engine exhausts and around engine nacelles. Flammability test specimens should be built‐up from the cowling/nacelle with the vinyl shrink wrap applied. 11. Peeling of the wrap from rain or hail. 12. Masking of cracks and corrosion in structure and skin. 13. Lifetime of a vinyl shrink wTap installation. How long before mandatory removal. 14. Effects of de‐ice fluids on the film. All great points. We have 42 vehicles at work and 40 of them are wrapped. We've installed some in house and some were outsourced. I sure wouldn't put a wrap on my plane knowing how it's installed. Sent from my Pixel 3 using Tapatalk 1
gsxrpilot Posted February 24, 2020 Report Posted February 24, 2020 So I guess wraps are ok for Part 25 airplanes, but not Part 23 airplanes?
chriscalandro Posted February 24, 2020 Report Posted February 24, 2020 (edited) 31 minutes ago, gsxrpilot said: So I guess wraps are ok for Part 25 airplanes, but not Part 23 airplanes? I’m told it’s a different material not available to us lowly GA fools. Seems like one of those rather bogus FAA rules. Edited February 24, 2020 by chriscalandro
carusoam Posted February 24, 2020 Report Posted February 24, 2020 Use an STC is what I think I read above... There are plenty of GA planes coming from the factory with large pieces of Vinyl... Getting the right stuff, put on the right way, seems to be important... MS has people with high speed vinyl graphics skills, and STC writing skills, anyone want to support a project getting an STC written? PP thoughts only, not a mechanic, or document writer... Best regards, -a-
chriscalandro Posted February 24, 2020 Report Posted February 24, 2020 I was going to call the FSDO Monday. I’d be willing to convert to experimental R&D to get it done and approved. to me it’s not a paint alternative, but an easy way to make a cheap basic white cheap paint job a path to something cool.
chriscalandro Posted February 24, 2020 Report Posted February 24, 2020 Ok, so I called the FSDO and they were a bit lost about it themselves. At the end of the day The line between graphics size and a full wrap is up to interpretation. An STC is the only way to go, and they think it wouldn’t be terribly difficult to get done and approved. So take that for what it’s worth
carusoam Posted February 24, 2020 Report Posted February 24, 2020 Makes a decent paint job look like the lower cost alternative... unless you are an airplane factory building hundreds of planes. you can always start with simple white... Then add stripes when the budget allows... Many Eagles started in a similar fashion and get additional art added to them over time... And nav boxes... and more hp... See Cris’ post from a few years ago... Best regards, -a-
ragedracer1977 Posted February 24, 2020 Author Report Posted February 24, 2020 21 hours ago, gsxrpilot said: So I guess wraps are ok for Part 25 airplanes, but not Part 23 airplanes? I imagine it's STCd. They use a special perforated vinyl. I can't even get a sample. 1
Bushbandit Posted July 31, 2022 Report Posted July 31, 2022 Ragedracer, I am contemplating this on a quite different AC.... a Zenith 701. If you have a chance, send me a PM. I have a few questions... Thanks!
carusoam Posted August 1, 2022 Report Posted August 1, 2022 Welcome aboard Bb! Lets see if @ragedracer1977 is around… He knows Vinyl! Best regards, -a-
Pinecone Posted August 1, 2022 Report Posted August 1, 2022 Hmm, from the attached list, tinting the windows needs an STC. 8. Tinting of windows and windshields with transparent vinyl, which compromises the view of pilots.
Hank Posted August 1, 2022 Report Posted August 1, 2022 11 hours ago, Pinecone said: Hmm, from the attached list, tinting the windows needs an STC. 8. Tinting of windows and windshields with transparent vinyl, which compromises the view of pilots. Windows can be tinted without STC if it doesn't compromise the view of the pilot. Darker tinting on back Windows, lighter on the front Windows, a dark stripe across the top of the windshield--these won't compromise your view. Dark tinting on the front windows is a different matter . . . . 1
Pinecone Posted August 2, 2022 Report Posted August 2, 2022 It doesn't say that it only has to compromise the pilot's view FORWARD. But I get your point.
