Quckid123 Posted February 10, 2017 Report Posted February 10, 2017 I'm new to Mooneys and have a dumb question. Where is the engine hour meter located? The tach doesn't have one and there is what looks like a hoobs meter by the passengers left foot. Quote
wpbarnar Posted February 10, 2017 Report Posted February 10, 2017 On the back wall of the luggage compartment, just below the hat rack. Bill Quote
Bob_Belville Posted February 10, 2017 Report Posted February 10, 2017 How about a Hobbs meter in a 68 F? Quote
DonMuncy Posted February 10, 2017 Report Posted February 10, 2017 40 minutes ago, Quckid123 said: I'm new to Mooneys and have a dumb question. Where is the engine hour meter located? The tach doesn't have one and there is what looks like a hoobs meter by the passengers left foot. If I am understanding your question, that one that looks like a Hobbs, is it. My understanding is that it reads engine time with a variation for engine speed. When you are running at the particular engine speed it is set for, it reads hours. If you are at a lower RPM, it will read proportionally less. At higher RPM, proportionally more hours. Quote
milotron Posted February 10, 2017 Report Posted February 10, 2017 The hobbs ( hour meter ) on my 1981 K is on the passenger side of the center console thingy, as you noted by the passenger left foot. Easy to miss if you don't know it's there. Quote
Guest Posted February 10, 2017 Report Posted February 10, 2017 Hour meters in tachometer are supposed to record time accurately at a specific engine RPM depending on the tachometer. Hobbs type hour meters just count when they are powered. Clarence Quote
bradp Posted February 10, 2017 Report Posted February 10, 2017 Not all Mooney's came from the factory with a Hobbs meter. Check your equipment list if you can't find it. It may not be there. Sent from my iPhone using Tapatalk Quote
