Calib18 Posted January 27, 2017 Report Posted January 27, 2017 im new to the form and a new mooney owner as well " first airplane I have ever owned " would love to have the valve so I can add heading hold to current wing level pc system if anyone knows where one might be or have one I have $$$ thanks
LANCECASPER Posted January 27, 2017 Report Posted January 27, 2017 Check with these guys: http://www.brittainautopilots.com/
Calib18 Posted January 27, 2017 Author Report Posted January 27, 2017 I have talked to jerry they have all the necessary parts to go with the BI-805 valve but not the valve . I have looked seems like in all 4 corners of the earth and cant find it
Marauder Posted January 27, 2017 Report Posted January 27, 2017 53 minutes ago, Calib18 said: I have talked to jerry they have all the necessary parts to go with the BI-805 valve but not the valve . I have looked seems like in all 4 corners of the earth and cant find it What does the valve look like? Some one may have kt in their toy box.
Calib18 Posted January 27, 2017 Author Report Posted January 27, 2017 This is the valve " To me this is worth more than a Lamborghini lol "
Marauder Posted January 27, 2017 Report Posted January 27, 2017 I have one of these. How does $480,000 sound? I should be able to get a nice Lambo for that much. Just kidding. Thanks for posting the picture. Hopefully someone has one. 1
yvesg Posted January 28, 2017 Report Posted January 28, 2017 Don't hold your breath. Have been looking for one for over 2 years now and still no chance. My wing leveler is performing very well and I have the electronic box. Yves
Calib18 Posted January 28, 2017 Author Report Posted January 28, 2017 I know, I have looked at all ends of the earth seems like , but you never know , I would absolutely love to find one there has to be a valve that could be used to replace this one , at this point I'd try anything lol
Yetti Posted January 28, 2017 Report Posted January 28, 2017 If you put "vacuum cutoff valve 12 volt" into google.
Calib18 Posted January 28, 2017 Author Report Posted January 28, 2017 It didn't bring anything up for me , I have herd some people have used a substitute valve and had good luck with it but finding what they used is like an act of congress
Yetti Posted January 28, 2017 Report Posted January 28, 2017 Oh wait this is the two way valve. One just sold on ebay. http://www.ebay.com/itm/Brittain-Autopilot-Components-14VDC-Turn-Coordinator-amp-BI-805-Control-Valve-/311554337565?nma=true&si=E81hc20KzTDWarazouLpsX0fOdc%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Yetti Posted January 28, 2017 Report Posted January 28, 2017 call beegles in greely colorado they were parting out a 76F. you might get lucky http://beeglesair.com/
Guitarmaster Posted January 28, 2017 Report Posted January 28, 2017 I have talked to jerry they have all the necessary parts to go with the BI-805 valve but not the valve . I have looked seems like in all 4 corners of the earth and cant find it Keep looking. Check eBay daily. Keep feelers out. Call all the shops you can think of. These get taken out with autopilot upgrades. Check Beech forums. I found mine in about three months. One will show up eventually.Sent from my XT1585 using Tapatalk
Mooneymite Posted January 28, 2017 Report Posted January 28, 2017 1 hour ago, Guitarmaster said: Keep looking. Check eBay daily. Keep feelers out. Call all the shops you can think of. These get taken out with autopilot upgrades. Check Beech forums. I found mine in about three months. One will show up eventually. What are these things selling for? I'm kinda surprised no one is manufacturing/re-manufacturing these!
Guitarmaster Posted January 28, 2017 Report Posted January 28, 2017 What are these things selling for? I'm kinda surprised no one is manufacturing/re-manufacturing these! I picked mine up for $650.Sent from my XT1585 using Tapatalk 1
dmc Posted January 28, 2017 Report Posted January 28, 2017 I've been holding on to this for a few years. I've sent it to Jerry for overhaul but never got around to getting it installed. Hopefully I'll have it in the plane this year. i picked mine up from someone upgrading there autopilot. Then I sent everything to Brittain to get checked out. They are out there, but for some reason the valve is hard to find. You think that they could make new ones for what I have seen these sell for.
LANCECASPER Posted January 28, 2017 Report Posted January 28, 2017 They might not have the part but if it's available they will will know who does: http://autopilotcentral.com/
Calib18 Posted January 28, 2017 Author Report Posted January 28, 2017 DMC would you take 3000 cash for your set up ??? I can pay you tonight lol
Yetti Posted January 28, 2017 Report Posted January 28, 2017 The best I can tell this would be available in different form but same function. I know I have one on the plane, but not sure where it is. Have not seen it under the panel, but I believe that is where it lives. I would guess it opens to one side and close to the other to move the ailerons and rudder. Does anyone have a vacuum diagram? Pulling it out would reveal the secret in a few seconds and allow it to be matched to the correct one from here. https://www.parker.com/literature/Literature Files/IHD/DCsection.pdf
Calib18 Posted January 29, 2017 Author Report Posted January 29, 2017 I'm not sure where it's located i assumed in the tail near the rate gyro
N601RX Posted January 29, 2017 Report Posted January 29, 2017 It's a proportional valve. With 0 volts applied it is in the center position and directs vac equally to the left and right side. If a positive voltage is applied it increases vac to one side and reduces it to the other. With a negative voltage it does the opposite. The amount it directs to one side or the other depends on the amount of voltage applied. It's also counterbalance it isn't affected by bumps or turns. Brittian also sells a bi100 control box for another autopilot system they manufacturer that has a valve inside it that operates in a very similar fashion. There was another member a few months ago who was able to get a field approval to substitute the valve in the bi100 box. These are readily available and cheap.
Calib18 Posted January 29, 2017 Author Report Posted January 29, 2017 The BI100 is 28 volts ? How would I use this with a 12 volt system , any idea how I would find the old thread
Calib18 Posted January 29, 2017 Author Report Posted January 29, 2017 Just purchased the BI-100 12 volt valve , what would I need in conjunction with this to a tempt to have heading hold , I'll work with my AP and others to get this approved but would like to at least see if I can get it to work
dmc Posted January 29, 2017 Report Posted January 29, 2017 14 hours ago, Calib18 said: DMC would you take 3000 cash for your set up ??? I can pay you tonight lol Thanks, but I plan on getting it installed this year, unless I get surprised during my annual. Hopefully it won't cost to much to get installed. 1
