Guitarmaster Posted September 6, 2016 Report Posted September 6, 2016 Here we go!! I removed about 8lb of stuff from Riley today. The "demo" part of the project is done! Sent from my XT1254 using Tapatalk 8
Stetson20 Posted September 6, 2016 Report Posted September 6, 2016 Good luck! Keep posting updates and pics, please! 1
gsxrpilot Posted September 6, 2016 Report Posted September 6, 2016 I'm following this closely. I'll likely be installing an EDM-900 shortly myself. 1
Pritch Posted September 7, 2016 Report Posted September 7, 2016 Makes installing my EDM730 next week look like a piece of cake. Have fun and enjoy, half the fun of owning a Mooney is working on them. Pritch 1
Ratherbflying Posted September 7, 2016 Report Posted September 7, 2016 GM, while you have the circuit breaker panel pulled apart, reach back there and pull the avionics bus relay out and inspect the pins and socket. The relay is that gray cube that you can see in the sixth photo down. Clean off any carbon with a scotchbrite cloth and grease the pins before you reinstall. You will love your EDM900. Best thing I ever did for the aircraft. 2
StevenL757 Posted September 7, 2016 Report Posted September 7, 2016 And away we go Matt. :-) Excellent choice...and as others noted, you certainly won't regret it. Your engine will thank you. 1
Guitarmaster Posted September 7, 2016 Author Report Posted September 7, 2016 GM, while you have the circuit breaker panel pulled apart, reach back there and pull the avionics bus relay out and inspect the pins and socket. The relay is that gray cube that you can see in the sixth photo down. Clean off any carbon with a scotchbrite cloth and grease the pins before you reinstall. You will love your EDM900. Best thing I ever did for the aircraft. Great idea! Thanks! Sent from my XT1254 using Tapatalk
Marauder Posted September 7, 2016 Report Posted September 7, 2016 Another thing Matt, if any of those breakers are ancient history, you might want to consider replacing them. Good time while they are all easy to access. Sent from my iPad using Tapatalk 1
TWinter Posted September 7, 2016 Report Posted September 7, 2016 Lots of carnage happening on these olds birds lately. Glad to see everyone keeping them flying and upgrading. You will love it. -Tom 1
Marauder Posted September 7, 2016 Report Posted September 7, 2016 2 hours ago, Ratherbflying said: GM, while you have the circuit breaker panel pulled apart, reach back there and pull the avionics bus relay out and inspect the pins and socket. The relay is that gray cube that you can see in the sixth photo down. Clean off any carbon with a scotchbrite cloth and grease the pins before you reinstall. You will love your EDM900. Best thing I ever did for the aircraft. Matt -- Rather triggered another thought. If you have the machine gun landing light (button on the throttle), the relay for this circuit is buried in the back behind the breaker panel up on the side wall. Mine failed a year ago and was quite a pain to get replaced. They no longer make the exact relay and I have the details on the P/N for an acceptable replacement. 1
Marauder Posted September 7, 2016 Report Posted September 7, 2016 1 minute ago, TWinter said: Lots of carnage happening on these olds birds lately. Glad to see everyone keeping them flying and upgrading. You will love it. -Tom And I am even more happy it is YOU guys spending money and not me! 3
Guitarmaster Posted September 7, 2016 Author Report Posted September 7, 2016 7 hours ago, Marauder said: Matt -- Rather triggered another thought. If you have the machine gun landing light (button on the throttle), the relay for this circuit is buried in the back behind the breaker panel up on the side wall. Mine failed a year ago and was quite a pain to get replaced. They no longer make the exact relay and I have the details on the P/N for an acceptable replacement. I did think about replacing that. What is the P/N?
Guitarmaster Posted September 7, 2016 Author Report Posted September 7, 2016 7 hours ago, Marauder said: And I am even more happy it is YOU guys spending money and not me! If you would like to spend your money on my plane, I won't complain!! 1
Guitarmaster Posted September 8, 2016 Author Report Posted September 8, 2016 Small update: I had to order about $200 worth of hoses and fittings so that brings the total to ~$2900. Tomorrow will be pulling wires through the firewall, EGT and CHT probe install. Probably install the BI805 valve for the ACCUTRAK at the same time. Lots of work, but so far, not difficult. Pics to come. 1
Stetson20 Posted September 8, 2016 Report Posted September 8, 2016 Hat tip to ya, Matt. Like I said, project planes aren't my thing. Check your email. I may have found a better fit for me. 1
DXB Posted September 8, 2016 Report Posted September 8, 2016 I generally like my EDM900 a lot - had it about a year. Of course I was cursing a tad when my RPM sensor went bad in the middle of my Oshkosh pilgrimage. And the MP transducer is too sensitive, so it bounces a bit in flight - firmware upgrade didn't fix it. And I'm still waiting to get the right fittings to attach the snubber that JPI sent me for this problem. But overall it's really nice. 1
Guitarmaster Posted September 8, 2016 Author Report Posted September 8, 2016 (edited) Today found me installing probes and pulling wires. A label maker is nice to have as the mass of wires can get overwhelming. JPI makes it pretty easy by labeling most wires; however, most of said labels end up in the avionics bay so I added labels forward of the firewall. Should make connecting stuff up much quicker and more accurate. Since OAT and Oil Temp are options, I had to add them to the main connector. At the same time, I got the BI805 installed for the ACCUTRAK. Tomorrow I will be plumbing and connecting probes. Taking apart the "P1" connector. Beginning of the wire pull. Drilling for EGT probes CHT JPI Labeling OAT and OIL Temp added to plug Edited September 8, 2016 by Guitarmaster 2
StevenL757 Posted September 8, 2016 Report Posted September 8, 2016 Loving it...you're nearly there. :-) 2
Raptor05121 Posted September 8, 2016 Report Posted September 8, 2016 Awesome. What determines the distance from the cylinder head when it comes to EGT probes?
carusoam Posted September 8, 2016 Report Posted September 8, 2016 Standards used by the engine company... too close to the exh valve melts the probe. Too far away dulls the response. PP thoughts, not a mechanic. Best regards, -a- 1
Mark89114 Posted September 8, 2016 Report Posted September 8, 2016 I noticed a mark where you are drilling for the EGT probe. I hope you didn't use pencil. Somewhere I was told or read that you shouldn't use pencil on exhaust manifolds as their is some type of interaction between the pencil lead and the metal and will lead to cracks. If anybody can verify this or tell me old wives tales please correct me.
carusoam Posted September 8, 2016 Report Posted September 8, 2016 Not heard of that one... 1) Pencil lead is mixture of carbon black and clay. Carbon is probably not the issue. 2) potential of scratching the pipe surface may not be very good regarding stress multipliers... 3) That part of the pipe gets so hot there isn't much stress left on the red hot surface.... The installation procedure for the device probably has this information. JPI has their manuals online. See if they have the install details. PP only, my pipes were drilled at the factory. Best regards, -a-
Guitarmaster Posted September 8, 2016 Author Report Posted September 8, 2016 49 minutes ago, Raptor05121 said: Awesome. What determines the distance from the cylinder head when it comes to EGT probes? JPI says 2" to 4" from the flange. The factory probe was 4", so I followed suit.
Guitarmaster Posted September 8, 2016 Author Report Posted September 8, 2016 20 minutes ago, Mark89114 said: I noticed a mark where you are drilling for the EGT probe. I hope you didn't use pencil. Somewhere I was told or read that you shouldn't use pencil on exhaust manifolds as their is some type of interaction between the pencil lead and the metal and will lead to cracks. If anybody can verify this or tell me old wives tales please correct me. Have never heard that. Anyway, it's a grease marking "pencil."
Mark89114 Posted September 8, 2016 Report Posted September 8, 2016 Now you made me do some work and real research...... http://www.avweb.com/news/maint/183932-1.html Under maintenance practice they mention the pencil and it's affect. 1
