jrwilson Posted August 6, 2015 Report Posted August 6, 2015 Are these the same switches as used in a 231? Looks similar and they even have the right labeling and colored switches... Don't know the price but they have several distributers. Take a look maybe a good source? Sensata.com
Oscar Avalle Posted August 6, 2015 Report Posted August 6, 2015 I was wondering if I could use the switches on my M20C too to replace landing light, strobes switches, etc.
Marauder Posted August 6, 2015 Report Posted August 6, 2015 There is a thread around here where I posted the differences between the Klixon and ETA switches. They are different and at some point they began using ETAs. Where's Anthony when you need him?! Sent from my iPad using Tapatalk 1
testwest Posted August 6, 2015 Report Posted August 6, 2015 So, the way you can tell the Klixon from the E-T-A switches is by carefully looking at the switch actuator. The Klixon switches have hot-stamped lettering and the letters are actually indented some into the actuator. And, there is no printing on the very top of the actuator, that is the portion visible when it is off. The E-T-A switches are pad-printed, they look a little crisper and there is lettering at the top of the switch that also indicates its function [sTROBE LITE, ELEV TRIM, etc] that is visible when it is off. Here are a couple of photos: From left to right: The Master switch is a regular (two pole) switch, not a switch-breaker like the Klixon or E-T-A switches. Next is a Klixon RADIO MASTER switch in black. Next is an E-T-A EFIS MASTER switch, in black. Last is a switch blanker, these are made out of Royalite (Kydex, actually). Here is another photo: These are white Klixon switches, with one black one thrown in for good measure. There are also white E-T-A switches, I don't have any pictures of those. Shameless plug, the switches in the second picture are for sale $75 each. You will pay a lot more for new ones, even the blank ones in the original post here will cost you more. See the Avionics/Parts for sale forum. Thanks!
rbridges Posted August 6, 2015 Report Posted August 6, 2015 I know this isn't scientific, but to me, the klixon have a "softer" appearance. The ETA switches have a more defined edge. Also (with the mooneys, anyway), the white ETA switches are opaque whereas the Klixon switches are milky and somewhat translucent.
ArtVandelay Posted August 6, 2015 Report Posted August 6, 2015 Ok, I gotta ask, why can't you just substitute ETA switch for a Klixon if they are less expensive ?
testwest Posted August 6, 2015 Report Posted August 6, 2015 Unfortunately the ETAs are just as expensive, and the back is different, so they won't just screw into the AUX bus bar behind the panel.
testwest Posted August 6, 2015 Report Posted August 6, 2015 Unless you are saying substitute the ETA with a Klixon, that is doable but the ETAs look better. The ETAs are also out of production, unless Mooney managed to talk the Germans into restarting the line. The ETA base part number is 41-10-P10 by the way.
anthonydesmet Posted February 3, 2016 Report Posted February 3, 2016 Anybody know the best place to buy Klixon switches. Looking for a Landing Light. Also can someone confirm for me the model number. I have seen 20TC-BG-5 and 20TC-BG-25. Haven't gone to pull mine out yet.
Marauder Posted February 3, 2016 Report Posted February 3, 2016 Anybody know the best place to buy Klixon switches. Looking for a Landing Light. Also can someone confirm for me the model number. I have seen 20TC-BG-5 and 20TC-BG-25. Haven't gone to pull mine out yet. Black market. You can buy them new from Sensata. They don't sell them lithographed. If the switch is okay and the cover is broken, some people have had luck with a 3D print of a replacement. There is a thread out there that talks about it. Sent from my iPad using Tapatalk
anthonydesmet Posted February 3, 2016 Report Posted February 3, 2016 51 minutes ago, Marauder said: Black market. You can buy them new from Sensata. They don't sell them lithographed. If the switch is okay and the cover is broken, some people have had luck with a 3D print of a replacement. There is a thread out there that talks about it. Sent from my iPad using Tapatalk No, covers are fine, need to replace the actual switch
carusoam Posted February 3, 2016 Report Posted February 3, 2016 Part of the name of the switch is usually it's rating in amps. is the -5 for 5amps and -25 for 25 amps? The 20TC comes in two versions 2 and 4. 2= Recessed mount for below surface switch (similar to the O's panel I think) 4= more of a surface mount. Not seeing the BG option. May have been updated with the change to Sensata ownership? there are Mooney photos in this thread... How many amps is the Landing Lite circuit rated for? I haven't looked that up yet... This may be helpful...http://www.sensata.com/klixon/circuit-breaker-aircraft-20tc.htm There is a list of options that include Landing Light.... You can get a new cover if you are buying a switch. They also state 'don't risk ordering the wrong part. Call them or their distributor' Aircraft Circuit Breakers Fax: 1-508-236-1598 Customer Service - Pricing & Delivery Name: Angela Garvey email: agarvey@sensata.com Tel: 1-508-236-3536 Name: Gloria Chaves-Doherty email: gchaves@sensata.com Tel: 1-508-236-3539 General Questions Name: Betty Detore email: klixon@sensata.com Tel: 1-508-236-3287 Marketing & Technical Support Name: Susan Rogers email: sarogers@sensata.com Tel: 1-508-236-3753 I had contacted Susan Rogers back in 2014 trying to get to the bottom of the printed switch covers debacle with no result. Best regards, -a- 1
anthonydesmet Posted February 3, 2016 Report Posted February 3, 2016 Thanks! I also just got home and pulled out my electrical schematics and it's a 25 amp breaker switch for the dual 100w lights. Sent from my iPhone using Tapatalk
carusoam Posted February 3, 2016 Report Posted February 3, 2016 Following that guidance.... A 20TC2-25 (Check the details with your mechanic prior to ordering) share this with him... http://www.sensata.com/download/drawings/20TC2_J.pdf The switch covers are from the same data sheet.... The document calls it a button cover or rocker button. I get the feeling that the marketing person I communicated with may have not known they are giving the part numbers on their website. They are confused with the differences between buttons and rockers... Rocker button options for SR12507-156-X X Options 1 Push On / Landing Light 2 Push On / Nav Light 3 Push On / Anti–Coll 4 Push On / Pitot Heat 5 Push On / Boost Pump 6 Push On / Glide Slope 7 Push On / Marker Beacon 8 Push On / Strobe Light 9 Off 10 Off 11 "SR to Invert Marking" 13 Push On / Rotating Beacon 16 Push On / Elevator Trim 18 Push On / Radio Master 19 Push On / LDG Light 20 On / Off 21 Off 22 "Colored Box" 23 Off 25 On / Off 26 Off /On 27 Push On / Low Boost 28 Push On / High Boost 28 Push On / High Boost 29 Push On / WX Radar 30 Push On / Prop De–Ice 33 Push On / Standby Vac 34 No Actuator 35 On / Off For others, please contact us.
Marauder Posted February 3, 2016 Report Posted February 3, 2016 Part of the name of the switch is usually it's rating in amps. is the -5 for 5amps and -25 for 25 amps? The 20TC comes in two versions 2 and 4. 2= Recessed mount for below surface switch (similar to the O's panel I think) 4= more of a surface mount. How many amps is the Landing Lite circuit rated for? I haven't looked that up yet... This may be helpful...http://www.sensata.com/klixon/circuit-breaker-aircraft-20tc.htm There is a list of options that include Landing Light.... You can get a new cover if you are buying a switch. They also state 'don't risk ordering the wrong part. Call them or their distributor' Aircraft Circuit Breakers Fax: agarvey@sensata.com Tel: gchaves@sensata.com Tel: klixon@sensata.com Tel: sarogers@sensata.com Tel: 1-508-236-3753 I had contacted Susan Rogers back in 2014 trying to get to the bottom of the printed switch covers debacle with no result. Best regards, -a- Nice reply Anthony. 1
carusoam Posted February 3, 2016 Report Posted February 3, 2016 Chris, Thanks for the kind words... I have been working on this one for two years. With a decade of M20C experience including swapping out the landing light CB. I wish all the answers would come this quickly. Which cover did you need to replace? I feel confident that I could actually order the right cover given the details I just updated. I would start with the distributors first, though! I think I may have solved a mystery that the vendor may actually appreciate. Best regards, -a-
carusoam Posted February 4, 2016 Report Posted February 4, 2016 I have contacted Aircraft Spruce. They have customer service online with limited tech support. I sent the details to at least see if they can source these wild geese. I'll copy the response when I get one... Best regards, -a- 2
NotarPilot Posted February 8, 2016 Report Posted February 8, 2016 I'm definitely interested in replacing my switch covers preferably with new black labeled ones. I tried the black 3D printed ones but had to stick the labels on myself and they just don't "look right." If you can get some properly labeled black switch covers for Klixon switches I'd be in on that order if they're somewhat reasonably priced in aviation terms.
carusoam Posted February 8, 2016 Report Posted February 8, 2016 The question keeps bouncing back to 'how many do you want'? Which is standard for, if you buy the switch you get a cover for free. It is clear that the CB/switches are still good, but the plastic covers are old. Which I interpret as I need to keep working on it. It is possible that there is a better partner than Aircraft Spruce. I'll reach out to a couple other similar resources that may be better this week. The switches and their covers are still in production. The printed version is the same for all aircraft, their not Mooney specific. The risk for them to carry in inventory is not terribly large. I'll be on a mission starting tomorrow. Best regards, -a-
NotarPilot Posted February 8, 2016 Report Posted February 8, 2016 I would like eight, preferably black. My red "Battery" looks good. One labeled "radio master" and these in the picture... 1
Marauder Posted February 8, 2016 Report Posted February 8, 2016 The question keeps bouncing back to 'how many do you want'? Which is standard for, if you buy the switch you get a cover for free. It is clear that the CB/switches are still good, but the plastic covers are old. Which I interpret as I need to keep working on it. It is possible that there is a better partner than Aircraft Spruce. I'll reach out to a couple other similar resources that may be better this week. The switches and their covers are still in production. The printed version is the same for all aircraft, their not Mooney specific. The risk for them to carry in inventory is not terribly large. I'll be on a mission starting tomorrow. Best regards, -a- Anthony -- if they are able to procure switches and covers separately, it allows the matching of cover to correct amperage. It also will allow Cheap Bast$&ds like me to buy just the covers to replace all of my deteriorating ones. If they are priced right, I would buy a whole set. I don't know how much of a break they will get to make it worth their while. Hope you you are successful. This is one of the Holy Grail items. Along with a cheap replacement for the ram air induction boot. Sent from my iPad using Tapatalk 1
Oscar Avalle Posted February 8, 2016 Report Posted February 8, 2016 If the price is right then I also would buy a whole set of covers Oscar
Steve Dawson Posted February 8, 2016 Report Posted February 8, 2016 (edited) Here's a list of suppliers that have both used as well as new: http://www.controller.com/list/PartsSearch.aspx?PartNum=20TC2 I lucked out when my landing light breaker went and found one on ebay and just for safety bought a new one from Sensata for approximately $240.00 last year Edited February 8, 2016 by Steve Dawson
carusoam Posted February 9, 2016 Report Posted February 9, 2016 Update: I sent Sherry at LASAR an email today. I think if anyone has the way to access and supply these parts it may be LASAR. The channel between Aircraft Spruce and Sensata is not a straight line... Best regards, -a-
Marauder Posted February 9, 2016 Report Posted February 9, 2016 Update: I sent Sherry at LASAR an email today. I think if anyone has the way to access and supply these parts it may be LASAR. The channel between Aircraft Spruce and Sensata is not a straight line... Best regards, -a- Keep after them tiger! We need those switches! Or at least the covers! Sent from my iPad using Tapatalk
