Marauder Posted June 30, 2015 Report Posted June 30, 2015 Similar to the avatar bug? -a- Don't know but it is weird... N10CH is an F but apparently not his. Sent from my iPad using Tapatalk
Ned Gravel Posted June 30, 2015 Report Posted June 30, 2015 My max personal altitude in my E is 7000. It will go higher My max duration is 1.5 hr This is a great expansion of my personal envelope from my old Grumman which had a functional ceiling of 6000 ( it won't climb past that) If the July 4th weekend is good I going to push that envelope a bit . I am not ready for Oshkosh yet. carl Carl: When you feel ready, sign up for a Caravan clinic. It will make your first time to Oshkosh something other than absolute gripping fear - watching sixty aircraft bimble their way through the Fisk arrival with you hoping that the ones closest to you actually see you as you enter whatever pattern the pink shirted crew have assigned you praying that none of them are trying to put theirs down on the same dot as you. In the Caravan, you will get to fly with 35 or so of your newest bestest friends, all going in the exact same direction and with a demonstrated level of skill in getting there proven to avoid bumping into anyone else in the doing of it. And the photo is cool too! 2
