Rod Vivian Posted May 12, 2015 Report Posted May 12, 2015 Currently I have just sealed off the sump because it leaked, the valve works fine. My mechanic wants to replace the assembly, is that necessary? I don't want to get it all apart and get stuck. Quote
Rhumbline Posted May 12, 2015 Report Posted May 12, 2015 Give LASAR a call. Depending on the assembly, it can probably be overhauled. A year ago it was $350 and they had it for only a day. Hope that helps. Quote
lamont337 Posted May 12, 2015 Report Posted May 12, 2015 Give LASAR a call. Depending on the assembly, it can probably be overhauled. A year ago it was $350 and they had it for only a day. Hope that helps. They did mine for about half that but maybe it's a different model or needed less work. I don't have the one with the pull ring but it can be sumped from below. Quote
