CCowboy Posted September 29, 2014 Report Posted September 29, 2014 I have the CO Guradian panel mount. It replaced a failed Davtron clock. With this I get CO warning PLUS Timer, clock, density alt, temperature (in and out) and voltage. It only has sounded once when taxiing with the door open and wind from 2 o'clock. It also beeps when crossing 10K and 12.5 K. I really like the instrument. I like the panel mount, don't like plug in things, wires, and "home depot" type things laying around the cockpit. Quote
Piloto Posted September 29, 2014 Report Posted September 29, 2014 A friend of mine gave me this one. It has a red light and a voice warning. Tried with fried hot Mexican beans and it works. Quite sensitive 1ppm (peo per minute). Made in USA José 1 Quote
JohnB Posted October 2, 2014 Report Posted October 2, 2014 John, Got a message that link needs to be updated.... http://www.aeromedix.com/safety-equipment/carbon-monoxide-detectors/ Is this the one you meant? Best regards, -a- CO2 = not so bad... CO is the killer! Yes. thats the one Caruso. Ultra low level Carbon Monoxide detector. Thanks for the typo correction, yes its CO. Would HIGHLY recommend everyone who owns, or regularly flies a plane get one, and not the one from home depot, or the color changing card. One quick blast about the CO color changing card, one of the FIRST things to go with Carbon Monoxide inhalation (CO) is your color discrimination, so if you actually did have enough CO in your cockpit to change the color, you would have NO idea what color it was, even if you were to somehow, luckily look at it while inhaling which would be unlikely. Because of my recent detector purchase I am having my mechanic check out the levels that Im seeing on runup and fix it! If I never had bought one, I would have never known, even with that home depot one I used to have. Quote
