According to a weighing certificate on my m20j, the empty weight is 1983 lb. It sounds a bit heavy. Is it normal or shall I get it checked. All the previous ones I looked at where about 1830...
Sent from my SM-N9005 using Tapatalk
Tj I emailed you back on Mooneyspace but have no clue if it went through. We're now playing Fire Thorne on Sunday am.. Based on Wx not sure what day I'm at the Open still hoping for Friday.. T storms sch for thur pm when I planed to fly.
I got it, thx, hope you have good wx.
Mine is 1887, also with a 3-blade prop and a few avionics extras.  1930 would be a stretch I think.
My little '66E with I pc belly, speed brakes, bladders, Scimitar prop is 1660 (w/o oil, fuel). (The original factory weight was 1611 w/o oil fuel.)
I would think a J would be at least 100 # heavier than my factory weight.
I think I have every speed mod, plus speed brakes, and you're correct, 1802,
I'm hoping to lose some weight during my avionics upgrade.
My new panel saved 17#. Removed ADF, KNS80, etc.
  • 2 weeks later...
According to a weighing certificate on my m20j, the empty weight is 1983 lb. It sounds a bit heavy. Is it normal or shall I get it checked. All the previous ones I looked at where about 1830...Sent from my SM-N9005 using Tapatalk
Maybe it was weighed next to the gravational pull of C182?
