SkyBound Posted April 23, 2014 Report Posted April 23, 2014 One final plea to the group to see if anyone may have an Aerosonic Part #651035-0107 (see photo below) combination Manifold Pressure/Fuel Flow gauge for sale before I splurge on a replacement equivalent and an expensive install. Thanks. --Alex 1 Quote
MARZ Posted April 23, 2014 Report Posted April 23, 2014 Don't see the photo but restrict your goggle search to Aerosonic 651035 saw some that were Beechcraft specific. and one that matched the suffix but was in as removed status Quote
SkyBound Posted April 23, 2014 Author Report Posted April 23, 2014 Thanks Mike. I have reloaded the photo. Looks like it shows up now. Quote
jwilkins Posted April 23, 2014 Report Posted April 23, 2014 Pacific Southwest Instruments has this listed as one they can repair. http://www.psilabs.com/MRO/Aerosonic/manifold-pressure-fuel-flow-indicator/651035-0107 Lasar typically can get almost any of our instruments overhauled - talk to Dan Reisland in Parts - (707) 263-0581 I found an as-removed instrument a few years ago just to keep the OEM working but it's not as accurate as the JPI. The newer heads with the fuel totalizer capability can be installed and will work for FF and MP without having to install the totalizator computer/ display Quote
SkyBound Posted April 23, 2014 Author Report Posted April 23, 2014 JWilkins, Thanks for the link to PSI - my instrument has spent the last month on their bench and they have finally concluded that they are not going to be able to fix it. I have spoken to LASAR, thank you for that suggestion. There is not much they can do at this point. This helps me confirm that I have exhausted all the options. I really appreciate you taking the time to post. I am likely going to go with Aerospace Logic as the solution. http://www.aerospacelogic.com/index.php?dispatch=products.view&product_id=232 --Alex Quote
N601RX Posted April 23, 2014 Report Posted April 23, 2014 Consider the JPI 900 also. They have a really good deal on them right now, under 3K. If you don't already have a engine monitor it will be a very useful addition and add value to the plane. If you already have an older one you can sell it to recoup some of the cost. 1 Quote
SkyBound Posted April 23, 2014 Author Report Posted April 23, 2014 I just upgraded to the JPI-830 over the summer and was hoping to keep this instrument replacement to a minimum and thus have decided not to look at the 900/930 as an option. I expect the install costs would still be significant and then there is the whole controversy of keeping the harnesses and sensors or replacing them... --Alex Quote
KSMooniac Posted April 23, 2014 Report Posted April 23, 2014 You could re-use what is already in the plane if you wish, and just add the additional sensors to bring it up to the full -900 kit. Quote
Jeev Posted April 23, 2014 Report Posted April 23, 2014 On 4/23/2014 at 9:52 PM, bluehighwayflyer said: FWIW, I have several Aerospace Logic instruments installed and have had nothing but excellent service from them. Jim If they are the same as Aerosonic (OP's post) I agree! I just pulled a failed Aerosonic turn coordinator and it was dated 1978 with no overhaul!!! That is 36 years and 4700 hours of operation from an electric gyro! Quote
jwilkins Posted April 23, 2014 Report Posted April 23, 2014 I'm disappointed Dan @ Lasar couldn't help you. He's a great resource. It used to bother me that repairing our old instruments was so bloody expensive. It's worse now that we don't have that option at any price. I have a JPI 830 in the plane but it's not supposed to be an approved replacement, so I R&R'd the inop Aerosonic with a used unit. The JPI is much more accurate (based on refueling numbers). Jim Quote
Mike A Posted May 19, 2015 Report Posted May 19, 2015 If the unit is repairable, Air Dallas Instruments will do it for $320. Quote
