My "wing walk" is not looking best anymore. What is the best way to repair? Does the old stuff need to be removed? Do you just "paint" over the old to fill the holes?
What kind of a compound is neeed? How to proceed?
Since this is totally new for me, any advice is much appreciated.
Here are some pictures of what the "wing walk" looks like:
Posted ImagePosted Image
Search for a thread from a year or so ago. Several of us have done this job, simple and cheap. I recall providing step by step advice using a small can of material from Aircraft Spruce and a narrow napped paint roller. Clean thoroughly, dry, mask, and roll right over the old.  (The grit settles quickly, keep it stirred.)
I would use caution in applying too much wing walk compound. Rolled on too wide and too think destroys the beautiful clean airfoil and adds un wanted drag.
Paint stripped is required to removed it.
  On 2/1/2014 at 10:04 PM, laytonl said:
Randolph wing walk compound is the material. I prefer to brush it on. Lee
Lee, Lynn uses a roller. In fact he loaned me his and stirred my can on his drill press. But I did the work. :) We're lucky to have him.
  On 2/1/2014 at 10:35 PM, Marauder said:
That's the stuff...
that's what I used, too.  Cleaned the wingwalk to remove oil/residue and marked the edges with blue painters tape.  I bought a cheap roller (it's going to be toast afterwards) to apply it.  Looked great.
make sure to stir it well.  The grit is probably settled to the bottom of the can.
I looked at the thread from last year. Thanks for the tip!
A number of comments refer to "cleaning" the existing wing walk before reapplying. How do I clean? What solvents/material are best used?
Is it best to wait for a certain outside air temp before I do this project? Should I wait for spring or is this something I can tackle now? (
I just used a spray degreaser like Purple Power from walmart.  I think mine cured pretty quick b/c I did it when it was fairly warm.  There was one spot where I had to fill in a void and it took a few days to harden.  I would just stay off it for a while, especially if it's cold and humid where you are.  Worst case, you put a shoe mark in it and have to repaint an isolated area.
paint remover to remove the old wing walk
fine sand paper to remove any corrosion patches
spray Zinc chromate
apply wing walk compound. 1 layer should suffice.
Really the most difficult part will be to protect the non walk area with paint tape.
and as mentioned somewhere above, make sure you stir the pot really well as the grit tend to settle. use a long screwdriver or steel rod to scrape the bottom of the pot and make sure the grit is in suspension.
do yourself a favor and do not patch the current wing walk.
very easy and fun job.
tools and products needed:
wing walk randolph
paint remover ( home depot)
zinc chromate spray
plastic and/or metal spatula to scrape old paint
plastic sheet to protect plane from spray
fine sand paper
paint tape
OR75 mentions to "not patch the current wing walk". Since mine still looks pretty good (see pics above) would it not be OK to paint over the old?
Let me be a contrarian here.
If what bothers you most about your wing walk is its appearance (after all, 95 % of the compound is still there, doing it's thing) then I'd suggest buying some flat black paint, taping the edges for a nice, neat appearance, and rolling it on. I did this 5 years ago with my wing walk and it has held up well. If and when it starts showing its age, I'll redo it.
Mine was fine, too.  Just faded and a few stains.  Stripping would probably be more ideal, but mine has held up well for 2 years since repainting it.
Years ago in an Arrow I had I repainted the whole area with Randolph wing walking compound using a paint brush and could not get rid of the brush marks. The stuff is very thick and does not smooth out by itself. I would recommend using a short nap roller.
How do you use paint stripper and not destroy all the surrounding painted areas?  Very carefully I guess?
Seems like the stripper would 'bleed under' the painter's tape and ruin paint.
