Depends how broken it is. Signal still ok ?
That is a question I am not sure of, I have been having problems with the GS coupling to the autopilot, they just changed out the coax coupler and that helped considerably.  But still nothing like my old Piper Saragota did.  I have concerns that there might be some other issue and when I found this yesterday it give me even more concern!
The avionics shop measured and found that after the coupler was changed the signal being received from their very low power transmitter was greater by about 400% ie 40ft vs 10ft before the coupler was changed!
So my questions remains?  Any thoughts, my thought is repair the structure of the antenna (the tube, which I believe to be stainless or possibly aluminum) if by chance the electrical conductors are in tack until I get it repaired or replaced.
I have those on my salvage plane if you need a replacement. Sent from my ADR6425LVW using Tapatalk
Scott, please PM me I am interested in learning more on the unit you have.
Thanks in advance,
Lacee
