Voltage regulator went on sabbatical today.
95 M-20R. Model 28vdc/single alt.
P/N 800270-501 K
S/N 0440
Any help in locating another would be greatly appreciated.
Thanks,
DH
should not be too difficult.
since you have the part number and serial number, i assume you must have located where it is.
Just call Zeftronics and ask then wich one is a drop in replacement
Andy rings a bell, IIRC there is a ten cent piece inside which blows out, but Don found a local place to rebuild them.
Thanks guys,
As mentioned above, unable to cross reference with a Zeft. unit. Found Don's contact info on a previous Mooneyspace blog and will contact him today.
For a repeat of his contact info: 903-643-9902, email: service@donmaxwell.COM or postal at 390 Central Rd., Longview, texas 75603
Above info much appreciated as am presently grounded.
Not the same situation as yours, but my "Over-voltage" light started coming on occassionally.  Since I was going on a long cross-country, I went to Aircraft Spruce and bought a replacement voltage regulator (controller?) and put it in the baggage compartment, lest I have trouble on the road I'd have the part.
When  got back, I cleaned several electrical grounding points.  I've never had another "over-voltage", but that is probably because that new part is still stored in the baggage compartment...not because I cleaned the grounding points.    :rolleyes:
Presently,
Unit is enroute to Maxwell aviation services for rebuild. FYI, just received e-mail quote from WB Parts Inc. for a factory new 800270-501 for
$2,500. Evidently, a hard to find item.
No joy with Zeftronics. That is the reason they are asking $2500 for a $150 dollar part.
Maxwell is the man when you have issues with this item.
