MichiganMooney Posted October 19, 2013 Report Posted October 19, 2013 My electric fuel pump switch on my '77 M20J does not work when the temperature is below 40 degrees. It is impossible to turn on. When the cabin warms up, it functions normally. Is there anything that I can do (such as lube) instead of replacing it? Thanks, - Wendell Quote
MichiganMooney Posted October 20, 2013 Author Report Posted October 20, 2013 Where is the best place to buy Tri Flow? Can you buy it in a store? Quote
Rwsavory Posted October 20, 2013 Report Posted October 20, 2013 Where is the best place to buy Tri Flow? Can you buy it in a store? Bicycle shops carry it. Quote
The-sky-captain Posted October 20, 2013 Report Posted October 20, 2013 Any of your local bike shops should have Tri-Flow. Quote
fantom Posted October 20, 2013 Report Posted October 20, 2013 Ace Hardware usually carries it, as well. Quote
N601RX Posted October 20, 2013 Report Posted October 20, 2013 It can also be ordered from Mcmaster Carr in both spray and small bottle. I would personally replace the switch. Quote
