marky_24 Posted October 15, 2013 Report Posted October 15, 2013 I lost one of the bottom screws on the hinge to the storm window. Does anyone know were to source a replacement? Or even what size and type it is? It's on a78 201. Quote
MARZ Posted October 15, 2013 Report Posted October 15, 2013 When you get your replacement - install them with the "special" screw to the inside - that way when they it loosens up (again) the hard to replace one will fall inside the plane..... I lucked out on that one! Quote
Jamie Posted October 15, 2013 Report Posted October 15, 2013 What's a storm window? Is that the pilot's side little vent window? (asks the owner of the '81 201... do I even have this?) Quote
N201MKTurbo Posted October 15, 2013 Report Posted October 15, 2013 It is the little window What's a storm window? Is that the pilot's side little vent window? (asks the owner of the '81 201... do I even have this?) It is the little window that lets you stick your arm out with a credit card to scrape the ice off of your windshield while flying. 3 Quote
N201MKTurbo Posted October 15, 2013 Report Posted October 15, 2013 The fasteners are called Sex Bolts I think they are 8-32 1 Quote
fantom Posted October 15, 2013 Report Posted October 15, 2013 You don't need screws or sex bolts. Suction alone will keep the window closed. Quote
N601RX Posted October 15, 2013 Report Posted October 15, 2013 Just don't pry it open in flight if you have a Brittain Altitude hold. About 2 seconds later you will get a full nose down response. Not fun at all, learned the hard way. Quote
Sven Posted October 15, 2013 Report Posted October 15, 2013 Another name for it is a Binding Post. McMaster is an amazing place to find strange hardware (and the normal stuff) often cheaper than Spruce. http://www.mcmaster.com/#binding-posts/=oy8w0y Quote
marky_24 Posted October 16, 2013 Author Report Posted October 16, 2013 Here are the Mooney part numbers,AN507-632r3 screw, 914071-005 for the "nut" end. So far i have a quote for the low low low price of $9.79 for both. I think ill look locally before i give in to the airplane tax on this one. Quote
N201MKTurbo Posted October 17, 2013 Report Posted October 17, 2013 I think this is the nut: http://www.fastenal.com/web/products/details/0123389 Quote
