Thanks,
The hero3 was mounted on top of the right wing...the wind wasn't too bad at all...a little gust just prior to touchdown to make things a bit interesting, but no real surprises, at 45min less than full fuel (with bladders) and 2 pax, i was a bit under max takeoff weight..sprung off the runway, like she longed to be back in the air !..ill have a second part of this vid,(return trip) with a different view...trying to get 2 cameras to co-operate at once...
the go pro is in its waterproof case with the suction cup mount
Be careful with that mount. The surface mount is not so sturdy when you use it on the wing and you may lose the camera. It happened to me and I lost a GoPro.
