Lood Posted April 21, 2013 Report Posted April 21, 2013 There's a very nice looking, low time 252 for sale here in SA and two interested buyers asked what the typical speed of the 252 is in terms of flight planning. I know a lot will depend on the specific power settings and especially the altitude, but what would the ball park figure be for, let's say 75% - 80% power at FL095 - Fl115 be?
gjkirsch Posted April 21, 2013 Report Posted April 21, 2013 I would think that about 170 knots at 10,000 feet to 195 knots at 20,000 feet buring 13.5 GPH would be in the ballpark
jackn Posted April 21, 2013 Report Posted April 21, 2013 I agree with gjkirsch. Mine has TKS, therefore it might be a couple knots slower than one without.
Steve Dawson Posted April 21, 2013 Report Posted April 21, 2013 Whats your need for a 252? If you're going between 9.5 and 11.5 maybe a 201 would work 1
Lood Posted April 22, 2013 Author Report Posted April 22, 2013 Whats your need for a 252? If you're going between 9.5 and 11.5 maybe a 201 would work It's not for myself, but for two other buyer that are interested in the airplane. Here in SA, very, very few pilots are IF rated in any way and South Africa is actually too small to really make a turbo charged airplane worth it - in my humble opinion. Distances flown are not that long, making the climb to high altitudes a waste. Most local private pilots fly less than 20 hrs per year. However, a turbo would be very nice at the higher altitude airports here, specially with our high summer temps. I've longed for one in such circumstances myself.
Earl Posted April 22, 2013 Report Posted April 22, 2013 I usually set mine for 65% power and at 11 gph in that altitude you will see around 165 kts TAS. As for the comment about flying in the 9.5 to 11.5 range, I do that fairly often to avoid the hassle of O2. But the 252 really earns its keep in the mid teens and at 75%-80% power setting you will easily see 180-190 kts but you will be burning a lot of fuel as you will need to run at 100 degF ROP or you will kill the engine.
Jeff_S Posted April 23, 2013 Report Posted April 23, 2013 I got this data from Parker when I asked about how he flight plans in his Encore. Not exactly the same as a 252 but should give you an idea: I typically cruise at 11.6-11.8 GPH which gives me the approximate speeds depending on altitude: 6000 - 160 KTAS 10,000 - 170 KTAS 14,000 - 175-179 KTAS 15,000 - 180 - 183 KTAS FL190 - 188-191 KTAS FL210 - 190-195 KTAS (195 is easy when you're lighter at end of trip)
Parker_Woodruff Posted April 23, 2013 Report Posted April 23, 2013 Not exactly the same as a 252 but should give you an idea: Power settings and fuel flows work out to basically be the same between the 252 and Encore since you're not using the extra 10 horsepower in cruise.
