Txbyker Posted October 29, 2012 Report Posted October 29, 2012 I am doing some avionics upgrades and am thinking about replacing my KT76A with a new mode S. The Garmin GTX330 would require some panel change but I understand the Trig TT31 is a direct fit for the KT76A. I know there are some folks here using the Trig. Can you provide feedback on the TT31 versus the Garmin GTX? Thanks Quote
podair Posted October 29, 2012 Report Posted October 29, 2012 I ve had a Trig TT31 in my M20F for five years. It has worked absolutely flawlessly. I had a KT76, so it was a 2 minute slide out , slide in job. Here in Europe you also need to apply for a minor modification ($300 fee plus $300 paperwork from the shop) permit whenever you change anything minor, unless the manufacturer has already applied for it on your behalf. To its credit, Trig pre-applied for dozens of aircraft type to the EASA , saving owners the fees, already suffering for having to upgrade to mode S (mandatory for IFR in Europe). Also happy to support the few European manufacturers that still exist. Installing a Garmin would have meant installation fees ($1000) plus the minor mod, so the choice was an easy one. It also has an ADS-B output I think, although here we can't use it yet (we get all the mandatory requirements without the side benefits, such as Mode S but no TIS, IFR GPS pretty much mandatory but you are required to keep ADF and DME). Having used both, I think the digit buttons on the Garmin are a good idea, but the squawk selection on the Trig with the knob is very easy too. I think Aviation Consumer had a review recently. If you have a KT76 I think it is a no brainer to use the Trig, unless you absolutely want to pay for some install work and have an all Garmin panel. Quote
OR75 Posted October 29, 2012 Report Posted October 29, 2012 chiming in although not directly answering your question. Mode S should not require re-wiring: the TT31 and KT-73 are mode S slide in. The (soon to be out ???) Avidyne AXP340 is also a slide in replacement to the KT-76A. For some reason ...at Garmin, they like to rewire even when not necessary (refer GNS to GTN ... ) ADS-B out will require a wire from a WAAS GPS. The GTX looks like a fine unit. I have not heard any bad things about the Trig. So the question may be: how much will it cost to rewire ? ps: does KDWH's 17L still have a lot of gravel ? Quote
Txbyker Posted October 29, 2012 Author Report Posted October 29, 2012 Thanks. I like that the Trig is a slide in replacement. I was told that the trays have to be modified for the Garmin and that the center stack is riveted to the side stack where my KT76 is today. I have also read that the Trig will not show traffic on the Garmin GNS as of yet therefore it may be a showstopper. OR75, Yep, 17L still has loose asphalt rocks sometimes. I avoid it if possible. Quote
STCAERO Posted November 15, 2012 Report Posted November 15, 2012 As the owner of an avionics shop in Spain, I´ve sold and installed about 25 TT31´s and to this date and never had a problem.They are both rugged and reliable and, as has previously been said, 5 minutes work, if that to install and program initially. However they won´t fit in a standard KT76 tray (and the connect is also different) - for a "plug & play" replacement you must have a KT76A or KT76C initially. STCAERO Quote
