Oscar Avalle Posted August 22, 2012 Author Report Posted August 22, 2012 Byron, excellent points. However, what do you do while your original gauges don't work... I had an AP that did not want to sign off my annual because the original CHT gauge was INOP (although I had a JPI 700). I went to another AP and he did not even mentioned that the gauge was not working. However, this time around, I decided that I would like to be fully legal... Quote
jetdriven Posted August 22, 2012 Report Posted August 22, 2012 Im saying before spending 1500$ chasing down 1963 stewart-warner senders get the JPI-930 for 3K. Quote
Oscar Avalle Posted August 22, 2012 Author Report Posted August 22, 2012 Byron, Fair enough. Oscar Quote
Sabremech Posted August 22, 2012 Report Posted August 22, 2012 Hi Byron, where are you finding a JPI 930 for 3K? The cheapest I found was $5500. Even the JPI 900 is over 5K. That's a lot of money to put into an old C model probably worth in the mid $30's. Quote
jetdriven Posted August 22, 2012 Report Posted August 22, 2012 OK fair enough. Whats the cheapest certified solution. Quote
Sabremech Posted August 22, 2012 Report Posted August 22, 2012 Mine will be when I'm done. Should be under $1000 for a duplicate of the original 6 pack, but with new instruments. I had some in depth conversations with my FSDO PMI about older gauges and having a reasonable solution and not in the $5000 plus category. That price Quote
N601RX Posted August 22, 2012 Report Posted August 22, 2012 I went back and fourth on this last year. The jpi 830 was $2600 and the ones that would let you remove the factory gauges was over twice that. I got the 830 and kept the old gauges. It isn't that hard to keep the old ones functional enough to pass annual. The biggest drawback to this is panel space taken up to 2 different sets of instruments. Quote
scottfromiowa Posted August 22, 2012 Report Posted August 22, 2012 Sign me up for the STC on the fuel gauges. VERY INTERESTED! I am Extremely satisfied with my G3 that is certified as primary for Cylinder temp and Exhaust. Provides redundancy on my additional digital EI certified primary Gauges for Tach, MP and oil pressure/temp. Bonus redundancy on fuel flow, voltage and I get outside temp too. I did individual gauges as I could afford spreading $ pain out. My fuel gauges work, but I really use the fuel flow as primary indicator and the gauges as confirmation. Hope you do the STC on the gauges and the cowl David. Quote
MagicCarpet Posted August 22, 2012 Report Posted August 22, 2012 Air Parts of Lock Haven rebuilt by original fuel gauges. Good shop. I will be sending my Fuel Senders from one of my fuel tanks to them soon for rebuild. Quote
