wburger1 Posted November 12 Report Posted November 12 Has anyone installed a GTN 650 and 750 in the center rack of an early M20 E or F model and can show a picture. Using just the racks to check for fit it does not seem to fit especially if they remote audio panel is mounted on top of the GTN 750. We are trying to put this in a 67F Model. It seems to have to be in the center rack as if we move it to the right the support rods are in the way.
TheAv8r Posted November 12 Report Posted November 12 Here it is in a '65 C model, same instrument panel / sizing. It's in the center. 4
Aerodon Posted November 21 Report Posted November 21 The 750 has a nice low rear end, especially without the remote audio panel. The remote panel does not have to be installed on top. And if you use a slim radio like the SL30, it can be installed a little lower. The GMC507 controller is also quite short behind the panel.
wburger1 Posted December 1 Author Report Posted December 1 On 11/12/2025 at 1:00 PM, TheAv8r said: Here it is in a '65 C model, same instrument panel / sizing. It's in the center. Wonder where they put the audio panel....
LANCECASPER Posted December 1 Report Posted December 1 13 minutes ago, wburger1 said: Wonder where they put the audio panel.... They must have used the remote audio panel. https://www.garmin.com/en-US/p/73817/
TheAv8r Posted December 1 Report Posted December 1 14 hours ago, wburger1 said: Wonder where they put the audio panel.... It was a remote install, controlled through the GTN750
